Monoprice rgbw dimmer
So I purchased 8 zwave rgbw dimmers from monoprice. https://www.monoprice.com/product?c_id=308&cp_id=30801&cs_id=3080102&p_id=36511&seq=1&format=2 . They seem to be whitelabel Qubino rgbw dimmers https://www.thesmartesthouse.com/products/qubino-z-wave-plus-flush-rgbw-dimmer-module-zmnhwd3 . Smartthings recognizes them as rgbw dimmers but the w channel isn’t handled properly as it attempts to make the leds mix to make white instead of lighting the white channel. I tried using the qubino handler that kjamesek made here https://github.com/kjamsek/SmartThings/blob/master/DeviceHandlers/Qubino/RGBWDimmer/QubinoRGBWDimmer_1_0.groovy however the devices arent created correctly as when i manually change them in the api i get a network or server area when click on the device or if i try to re-add the device it comes up as the default rgbw switch. I’m not a programmer per say but based upon what i’m finding i believe it has to do with the fingerprints for the hardware mismatching after looking at the code and looking at the device in the smart things api as like i said i feel its a whitebox version of the qubino. Any idea on what and how to edit the code to make it work correctly would be greatly appreciated. The raw device description from the api reads zw:L type:1101 mfr:0068 prod:0003 model:000B ver:2.13 zwv:4.24 lib:03 cc:5E,86,72,5A,73,26,33,70,85,59,25,7A role:05 ff:8600 ui:8600
