I actually found a solution about half an hour ago – Ive tested it from that time and it seems to be working
I was looking at the bulb and I guess Monoprice are changing manufactures because mine said
“HKZW-RGB01” in the actual model written on the bulb
I used this handler and it is now working with voice command
Only bad thing about this bulb is the the warm white is so bad (2700k) – cool white and daylight white are the only good ones.
