I have a Power Plug that uses the native “Zigbee Switch Power” DH. I currently have it plugged into a pump in my basement to monitor if the pump continues to run after X amount of minutes signaling to me that there’a problem. My new recent concern is what happens if the wife or kids switch off the plug by accident in the app and the pump never runs… UGH! so is there a way to modify that DH to run as a Power Monitor Only and disable the ability to switch it on and off from within the ST app? I’ve been trying and keep running into errors, so I’m now asking the Pro’s
- Copyright 2015 SmartThings
- Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
metadata {
definition (name: “ZigBee Switch Power”, namespace: “smartthings”, author: “SmartThings”, ocfDeviceType: “oic.d.switch”, minHubCoreVersion: ‘000.019.00012’, executeCommandsLocally: true) {
capability "Actuator"
capability "Configuration"
capability "Refresh"
capability "Power Meter"
capability "Sensor"
capability "Switch"
capability "Health Check"
capability “Light”
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0B04"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0702"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0702, 0B05", outClusters: "0003, 000A, 0019", manufacturer: "Jasco Products", model: "45853", deviceJoinName: "GE ZigBee Plug-In Switch"
fingerprint profileId: "0104", inClusters: "0000, 0003, 0004, 0005, 0006, 0702, 0B05", outClusters: "000A, 0019", manufacturer: "Jasco Products", model: "45856", deviceJoinName: "GE ZigBee In-Wall Switch"
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00A0DC", nextState:"turningOff"
attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00A0DC", nextState:"turningOff"
attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
tileAttribute ("power", key: "SECONDARY_CONTROL") {
attributeState "power", label:'${currentValue} W'
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
main "switch"
details(["switch", "refresh"])
// Parse incoming device messages to generate events
log.debug "description is $description"
def event = zigbee.getEvent(description)
if (event) {
if (event.name == “power”) {
def powerValue
powerValue = (event.value as Integer) //TODO: The divisor value needs to be set as part of configuration
sendEvent(name: “power”, value: powerValue)
else {
sendEvent(event)
else {
log.warn "DID NOT PARSE MESSAGE for description : $description"
log.debug zigbee.parseDescriptionAsMap(description)
def off() {
zigbee.off()
def on() {
zigbee.on()
def refresh() {
Integer reportIntervalMinutes = 5
zigbee.onOffRefresh() + zigbee.simpleMeteringPowerRefresh() + zigbee.electricMeasurementPowerRefresh() + zigbee.onOffConfig(0,reportIntervalMinutes * 60) + zigbee.simpleMeteringPowerConfig() + zigbee.electricMeasurementPowerConfig()
def configure() {
log.debug "in configure()"
return configureHealthCheck()
def configureHealthCheck() {
Integer hcIntervalMinutes = 12
sendEvent(name: “checkInterval”, value: hcIntervalMinutes * 60, displayed: false, data: [protocol: “zigbee”, hubHardwareId: device.hub.hardwareID])
return refresh()
def updated() {
log.debug “in updated()”
// updated() doesn’t have it’s return value processed as hub commands, so we have to send them explicitly
def cmds = configureHealthCheck()
cmds.each{ sendHubCommand(new physicalgraph.device.HubAction(it)) }
def ping() {
return zigbee.onOffRefresh()
