@cscheiene I couldn’t see the base sensor as well (only outdoor). After some debugging I found out that the:
apiGet("/api/getstationsdata",["get_favorites":true]) { resp ->
returns following data:
_id:70:ee:50:5f:45:5e,
co2_calibrating:false,
dashboard_data:[AbsolutePressure:1023.4, CO2:1024, Humidity:48, Noise:45, Pressure:1024.6, Temperature:23.9, date_max_temp:1636394515, date_min_temp:1636388210, max_temp:28.8, min_temp:20.4, temp_trend:up, time_utc:1636404446],
data_type:[Temperature, CO2, Humidity, Noise, Pressure],
date_setup:1635362800,
firmware:181,
home_id:61894c3e2bb03804801bc56b,
home_name:Foo,
last_setup:1636387902,
last_status_store:1636404447,
modules:[
[_id:02:00:00:32:d3:52,
battery_percent:100,
battery_vp:6526,
dashboard_data:[Humidity:79, Temperature:6.7, date_max_temp:1636388210, date_min_temp:1636400207, max_temp:23.4, min_temp:6.6, temp_trend:stabl, time_utc:1636404411],
data_type:[Temperature, Humidity],
firmware:50,
last_message:1636404444,
last_seen:1636404411,
last_setup:1636387903,
module_name:Outdoor,
reachable:true,
rf_status:59,
type:NAModule1]
place:[
// (PLACE DATA)
type:NAMain,
wifi_status:48
That means this conodition:
if (value.module_name != null) {
was always false and the base station was never added to the deviceList. I’ve modified the following app code:
deviceList[key] = "${value.station_name}: ${value.module_name}"
else{
deviceList[key] = "${value.station_name}: Main"
state.deviceDetail[key] = value
state.deviceState[key] = value.dashboard_data
and all works fine!
