On outdoor module I get a Carbon Dioxide Concentration tile, but I should only get this tile on the basestation module. Shouldn’t I get also the temperature trend?
The Wind Max capability tile now displays the unit!
No luck yet with outdoor module… If this is causing by the “classic” caching issue, I will update here once there is an update on its presentation.
Here is the vids:
Wind module vid: "787d5e2d-80e1-3f39-bf73-026acafdc48f”
Outdoor Module vid: “b6454229-3609-3701-bfef-25c9f8f36755”
I remove and add the device one more time and change the name once again. nothing happens.
Caching issues again? I let you know if something changes again
Dear all, I up to date all the device handler, and all work fine.
One more information for those who use Google Home.
As you know, google home does not support temperature sensors, but only thermostats, so by making this change to the device handler, you can transform the display of this sensor into a thermostat, and you can also view it on google home, but above all also ask the google assistant the temperatures of the various sensors you have inside and outside the house. I hope I enjoyed it, I’m not the expert, I only report the info received from another very kind user
@cscheiene@chewmull Unfortunately, the outdoor module hasn’t displayed the new capabilities yet. On dashboard view i’m getting still the humidity persistence instead of temperature.
unfortunately, I also had the external sensor that worked well, I thought it would be a good idea to update the DH because the IDE told me to be in conflict not for what reason … now the external module shows the battery percentage. Damn me for not standing still. Do you have any advice for me to get everything back to the way it was before?
@cscheiene one question for you: what do you think of my modification to the DH listed a few posts above to make it compatible with google home and being able to ask for the temperatures also from google home for each sensor? Do you use google home? Don’t think it’s worth implementing it in your future DH updates? or does it have any contraindications for those who do not use google home?
@Diegocampy
Try this:
Remove outdoor module via smart app,
Update to latest code,
Readd the module via smart app,
Rename the name (not label) credit: @cscheiene
