Hello.
Can you please add the capability “Sensor” entry on the Netatmo Basestation module DHT?
I was trying to create a webCoRe piston with this module, but it was not available on the list.
I add in the Device Handlers after this: capability “Thermostat”
after last "capability to add the possibility to ask at Google Home the temperature.
capability “Temperature Measurement”
capability “Sensor”
capability “Carbon Dioxide Measurement”
capability “Relative Humidity Measurement”
capability “Sound Pressure Level”
capability “Sound Sensor”
capability “Refresh”
capability “Health Check”
If you have other solution to use with google home let me know.
unfortunately the problem remains of not being able to ask for humidity, ppm or pressure, and in google home you will see all these sensors as thermostats
I’ve been able to make it work, my only concern right now is on my dashboard, both sensor do not show the temperature, they are just saying waiting on status… please see photo, sorry it’s in french as I am in Montreal Canada:)
I have the same issue on Netatmo and many other devices. If I change my phone system language to english it works, when I change it back to Norwegian it stops working.
So try changing your phone language to english. If it works, please report this to Smartthings so we can get it fixed. It’s only on Android, IOS works fine
I have created the smart app and see it in smartthings with the 3 netatmo devices connected. Beyond that have no reference to any information from Netatmo in smartthings app. Any clues on what I may be missing here?
Custom VID and capabilities are now released. I dont have much time at the moment, but have started to explore this. I have updated the basestation and additional module with custom VID. You can update and give it a try. You might have to remove and add the devices for the change to take affect
More capabilities are now displayed in the new app. Also temperature is set as default for the dashboard view for main and additional module. Later on it should be possible to also display status for the wind and rain module.
