Just selected a random station. It appears in the smartapp, but when I choose it I still get an error.
I typed in all the informations, as well as the number of decibels before it detects the sound.
(Sorry if Iām polluting the thread with the error )
Trying this myself. I installed the app and device handlers and logged into my Netamo account, but the app isnāt finding my two Netatmo sensors. What else do I need to do to bring them in? Thanks!
Are the modules missing completly from the āSelect devicesā list?
Have you followed the installation process in the first post and added everything in the app settings?
Can you give me the log info from when you try to install the smartapp in the ST app?
They are missing completely from the Select Devices list. I did follow the installation process in the first post. I noticed over at Netatmo thereās a feature I may need to switch on that would allow data from Netatmo to flow into the custom app, but since it wasnāt mentioned in the install instructions, I didnāt do it yet. Iām not sure where to get the logs yet to send you, but youāre welcome to PM me if you want (or reply publicly here) and weāll get it knocked out. Thanks!
I donāt. I donāt even have the wind or rain sensors. Only outdoor and one indoor unit. Basically why Iām testing this with SmartThings is the following: Iām an IT consultant for Earth Networks. We used to own WeatherBug but we sold WeatherBug to GroundTruth (formerly xAd). We were launching a new program called WeatherBug Home where we were interfacing with SmartThings and Netatmo and other weather stuff for home automation, energy savings, etc., with weather data, and Earth Networks bought me a SmartThings hub and a bunch of sensors for my home plus the Netamo so I could track temperature across my home for them. After we sold WeatherBug, we re-branded WeatherBug Home āConnected Savingsā and bought a new company Whisker Labs that also makes smart home sensors. We just spun off Whisker Labs into its own company, and Connected Savings will be a service they offer. Earth Networks will still play a major role with Whisker Labs providing weather data to them, and theyāre still going to be in the same building as Earth Networks, plus much of Earth Networks top management went to work for them. Iām still consulting for the āmother shipā Earth Networks, although Whisker Labs is letting me continue to test SmartThings and Netamo for them plus any new stuff Whisker Labs develops in house.
Thank you @MrRhubarb for being patient and providing me with all the information and logs so we where able to sort it out. I will do some changes so we can clearly see if someone has the same issue you had
I do have one peculiar situation: I am using webcore for my automation and it seems that main Netatmo module is only reporting integer temperature to Webcore. The temperature is showing properly in the ST client but when I assign the temperature to a value using Webcore it only shows as integer. (Even with decimal, or string as the variable type.
I have noticed what seems to be a bug when trying to get a refreshToken.
In refreshToken()
I changedā¦
state.accessToken = data.access_token
to:
state.authToken = data.access_token
AND
I changed:
if ( !state.accessToken ) {
return false
to:
if ( !state.authToken ) {
return false
Before I made this change the app would throw errors whenever it tried to get a refresh token, now it works great.
I followed all steps, can see my Netatmo devices on the ST app, but when I click āSaveā on the āChoose Devicesā screen I get a red āAn unexpected error occurred.ā Here is the debug from when I click āSaveā on the app:
