Strangely enough, I did the same thing in late November, switching from Telus to Koodo, however they are technically the same company.
I’ve noticed the improvement of the presence sensor too, but not 100%. I’d say 90% accurate this time, I still saw a long delayed presence update 2 weeks ago and that’s after my switch carrier. Not updated until I open the classic app to check.
It’s not related to any provider. Google changed Android a lot.
Based on personal experience, the only way to get consistent results an virtually no delays is to have phone connected to car and Android Auto running.
That did not work out for me either. I had seen couple of times when I used Android auto to do navigation for my commute and weekend routes, I still found my presence being home. There’s really no pattern to follow
I’ve had some brief luck using ADB to remove those overly aggressive task killers on my girlfriend’s Nokia 6.1, but it seems to only work for a day or two and then the problem persists. Hopefully this is something Nokia takes note of, as of right now its rendering a lot of my Smartthings automations useless.
Good call putting that together. I read about that issue but it didn’t click that it was probably the issue since its not my phone so I don’t get faced with the issue day to day. What is strange is I switched over to running IFTTT which is monitoring for a wifi connection which seems to work for the most part. I would have guessed that would get killed too, but maybe the act of connecting to wifi wakes it back up.
I didn’t use that guide, but that’s what I did. I’ll have to teach my daughter to kill that power saving app when she reboots. I even noticed that app running in the background. Shame on HMD. They are killing it with speedy updates and good low end phones, but app killers are a no no with today’s Android. Doh!
Read this whole thread and there’s lots of Google talk, but I’m having the same issue with iOS and the new app.
It worked perfectly until I switched to the new app a couple weeks ago.
Very sporadic and I can’t characterize the problem.
In my list of “members”, in addition to our two phones, there are two “Mobile presence” items listed. What are these? I thought there was 1 for each of us, but when my wife was removed from the list there were still 2.
I created 8 automations. 4 for these items leaving and 4 for these items arriving. I should get a notification for each. I’ve only ever received notifications for our phones, but it’s very irregular.
There are other disappointments with the new app, but this is by far the worst.
I went in SmartThings’ graph api and found that the two “Mobile presence” items were the same devices from the old app. I deleted them (one said I didn’t have permissions, but it worked anyway).
Let’s see what happens now.
What was I supposed to do when switching to the new app? Might have been wise to log out instead of just deleting it…
Lots of questions arise when you look in the graph api. All sorts of items you can’t see anymore in the new app. Seems like they are still working though.
True you’re supposed to keep using the classic app until they told you to migrate to the new one because not all smart apps and DTH are working in the new app.
As for the presence I don’t have much information since I’m still using classic and my wife’s iPhone is way better than mine in terms of accuracy.
Yeah, removing those from the old app didn’t seem to help at all. Still just as sporadic, mostly not working.
I have noticed a couple times that when I launch the app the notification for my mode change pops.
So now I’m wondering if the SmartThings app has to be running for this to work at all. So if the crashes or is closed in the background (which happens all the time) maybe it won’t work at all.
I resorted to getting a Samsung button that I have to remember to press or double press when I’m coming or going. So far this has been even less reliable…
So I think I may have figured out the issue for those that may be experiencing the same thing. I went into the Smartthings IDE and found that I had two HOME locations. One which had mostly all of my devices and one that had a couple devices. I found that one HOME was for my Smartthings Classic app (which I still use) and one was for the new Smartthings app (which I only use for my PowerBot). For some reason the phone presence was being added to the HOME for the new app. So I found that the HOME for the new app was set as my default location. So I changed my default location to the Classic app HOME and readded my phone as a presence sensor and it successfully added to the classic app devices. So far it has been working properly so fingers crossed!
