bamarayne
1
I know this had probably been discussed a million times already and that it seems almost unobtainable… But it’s really just a small request…
Can we please get a release of the Android mobile app that does not freeze every 30 seconds? I could probably live with a minute of use, as that’s a 100% improvement… But come on guys…
I guess I should be reasonable. I’ll compromise with 45 seconds but that’s as low as I’m going.
Mine freezes up periodically (on a Nexus device), but it doesn’t seem time related. Whenever it does freeze, I routinely clear cache before restarting it… just to be on the safe side. It seems that once the cache size gets to ~ 2.45MB, it’s just a matter of time.
bamarayne
4
Are you using it?? ? ? ? ?
bamarayne
5
I’ve noticed mine crashes a lot late at night. Usually starting around midnight cst until about 9 am cst.
Maybe it’s the night shift at ST. They are a couple of hours behind me…
I can tell you that this weekend was very frustrating. I have been here since the beta days and this is the the most “patience” I have had to exude.
I have an Android Lollipop phone and a Samsung Galaxy S Tab and both hung probably 50-60 times in the 2 days of installing 10 new devices. Every time I was creating a rule, flipping back and forth or saving changes the screen would go black and I would have to end the task and restart ST.
It has never acted like this since the beginning. I must admit I haven’t used the ST app much since SmartTiles came into the home so this might be Lollipop related.
I haven’t gone to support yet as I wanted to check the forum for ideas; I nothing concrete to give ST for troubleshooting.
Mine crashes and hangs like yours does. I keep a settings window open to force close it when I am programming. If I’m just turning on a light or manually running a routine it works ok. Version 2.0.5 seems to be a little better and at least seems to “crash itself” instead of me having to force close more often. I still have the final build of version 1 and am considering going back. It’s a good thing I’m retired. Keeping Smartthings working seems like a job since the release of 2.0. I didn’t upgrade and wish we could go back to pre 2.0 when.things worked pretty good, at least for me.
