Hi community,
I have the following questions (didn’t found any here).
I have a smarthings hub and a Aeotec Energy meter gen5 installed in my home.
First , how can i change the checkInterval variable or the variable that control the refresh rate? The report time of 5min is too long for what I want.
How can I have more data in the app? Like voltage, current, etc.
The Energy consumption chart shows a SUM of the previous data not the consumption by day or month. Is it correct?
Thanks in advance
Hi, have you solved? I have a similar question:
Hi, I need information on your smart meter. I’ve read on several sites that it can be configured so that you can, for example, change the refresh rate of the values. I don’t understand how to do it. My smart meter is connected to the Aoetec hub. I managed to configure everything on Smartthing and everything works fine. But I have no idea how to change the configurations. Do I have to do it from the Smarthings app? Do I need to do this by accessing the hub by IP address? How do I find the interface for changing parameters 101,103, etc etc?
Thank you
Smartthings is in the middle of a huge architecture, transition, so the answer from 2021 would not be the answer today in 2023.
I already posted a reply in your other thread:
