My classic app has never had problems with Greenwave zwave plugs. After migration the device is no longer visible in the new app
The plug itself has an automation from the classic app attached to it and if i search lighting automations in the new app and select to change the device the plug is visible but within the devices list in the new app it is not there
In the echo app using the new smattthings integration, the plug shows up and functions but shows connected via 0099-0002-0002 description smartthings
Any ideas why the zwave plug fails to show in the new app
As i use the terrible new Ui i seem to building a list of things that are not correct, i feel the list will get longer
Fibaro RGBWw controler
No device Ui options
Incorrect colour rendering using new app
Are you getting partial usability with the stock DTH or with the Codesaur DTH?
If it’s with codesaur DTH, you would need to contact that author, either through a forum thread here or through the github repository. Basically wherever you got the code.
If you are missing functionality with the stock DTH, you should submit that as a bug to support. Make sure you say that you are using the Samsung provided DTH, not custom code.
Its the same for the Fibaro RGBWw JD. The DTH was again by codersaur which exposed all the options available
The migration of the device and available current Ui restrictions really restrict the devices capabilities , this really has me worried, i put a lot of effort into the devices installation including attached LED strips and profiled external tracks, to loose complete control is extremely worrying
