How is everything? Is there anything in progress on the part of the ST team to release the feature of mirroring behavior that is currently available in the smartapp smart lighting and putting them also in the routines running locally?
Hi, there!
Iām discussing this with the engineering team to get a better insight as they are different integrations. As soon as I get their feedback, Iāll share it with you.
excellent! because for those who use virtual parallel the option of mirroring behavior is extremely important and as edge switches with more than one channel cannot rename them, it is impossible to use smart lighting for thatā¦ so if you migrate this feature to automations and running spot would be a genius move. Thanks!
The engineering team mentioned the mirror functions can be achieved using the Rules API and the changes
condition.
It is different depending on the capability configuration to set the attribute value.
For example, the Switch
capability has two enum commands that donāt receive any arguments.
In this case, we need to check the change to a specific value (āonā/āoffā) and send the same value to the other device.
This sample shows how we can mirror the switch events of a multi-component device that has a switch in two components (light
and main
), thatās also why only one deviceID
is used.
"name":"Mirror switch events of main and light components",
"actions":[
"if":{
"changes":{
"equals":{
"left":{
"device":{
"devices":[
"deviceID"
"component":"main",
"capability":"switch",
"attribute":"switch"
"right":{
"string":"on"
"then":[
"command":{
"devices":[
"deviceID"
"commands":[
"component":"light",
"command":"on"
"else":[
"if":{
"changes":{
"equals":{
"left":{
"device":{
"devices":[
"deviceID"
"component":"main",
"right":{
"string":"off"
"then":[
"command":{
"devices":[
"deviceID"
"commands":[
"command":"off"
"if":{
"changes":{
"equals":{
"left":{
"device":{
"devices":[
"deviceID"
"right":{
"string":"on"
"then":[
"command":{
"devices":[
"deviceID"
"commands":[
"component":"main",
"command":"on"
"else":[
"if":{
"changes":{
"equals":{
"left":{
"device":{
"devices":[
"deviceID"
"right":{
"string":"off"
"then":[
"command":{
"devices":[
"7eac1137-b397-4b22-ad63-24b67ee58fd6"
"commands":[
"component":"main",
"command":"off"
For capabilities that use a setter like switchLevel
itās easier, we just send the current attribute value in the command arguments.
In this sample, we mirror the events of dimmer 1 and dimmer 2 and itās not necessary using specific values.
"name":"Mirror dimmer 1 and dimmer 2 events of SwitchLevel",
"actions":[
"if":{
"changes":{
"operand":{
"device":{
"devices":[
"deviceID-dimmer1"
"component":"main",
"capability":"switchLevel",
"attribute":"level"
"then":[
"command":{
"devices":[
"deviceID-dimmer2"
"commands":[
"component":"main",
"command":"setLevel",
"arguments":[
"device":{
"devices":[
"deviceID-dimmer1"
"component":"main",
"attribute":"level"
"if":{
"changes":{
"operand":{
"device":{
"devices":[
"deviceID-dimmer2"
"component":"main",
"attribute":"level"
"then":[
"command":{
"devices":[
"deviceID-dimmer1"
"commands":[
"component":"main",
"arguments":[
"device":{
"devices":[
"deviceID-dimmer2"
"component":"main",
"attribute":"level"
I will create the feature request to have this in the mobile app Routines, but in the meantime, you can use this workaround.
Let me know if you have any questions.
very good to know that we will have this soon in the appās routines. For now I need to create 4 routines to mirror the behavior of 2 different devices, one of which is if connecting device 1 connects device 2; another to disconnect device 1 disconnect device 2: another to connect device 2 connect device 1 and finally disconnect device 2 disconnect device 1. Very laborious to do and this being the only alternative because as we canāt rename gangs in smartapp a huge list of switch1, switxh2, etc. appears. I will be looking forward to the update.
I cannot assure you this will be available soon, it depends on the prioritization and current workload of our team, as they are all, constantly working to build more cool features for you, please remember also, that you caught us in the middle of the holidays.
If you have any questions using the Rules API for the workaround I can help you out.
I never messed with the rules api. I would rather understand and know how I can make this work using it.
Thanks for posting that Nayely. Iām not particularly interested in mirroring but it hadnāt occurred to me that attributes could be used in arguments like that (that said, getting the right format for arguments has always been guesswork). Iād also been wondering what operand
was for. It is obvious now I see it used with changes
, not that Iāve found a need for that yet.
Any update on the mirroring feature being added to routines? I tried to get this set up based on @nayelyz 's code but I think creating a rule from code is too complicated for me.
@nayelyz, I was just looking at this again. While your example makes perfect sense, the API documentation describes the changes
operation as ā¦
A condition that returns true when its evaluation resolves to true and the previous evaluation resolved to false.
The main developer documentation says something similar.
Operand
is not explained in the API reference. It just appears to be a container. It isnāt clear how that can be true or false for a non-boolean attribute. So I donāt see how the documentation can be correct if your example works.
There is also a terminology issue (as ever).
- In the API reference
if
is an action andchanges
is a condition. - However in the main developer documentation
if
,every
,sleep
andcommands
are the conditions andchanges
,equals
etc are operations.
I see what you mean, this needs more elaboration on the functionality so we know what to expect.
- I think in the API doc, we need to change the text in parenthesis because despite
IF
being inside theactions
array (which is the task completed by the Rule), it is a condition. - Again, the value in parenthesis is the one that creates this confusion so, instead of reading
(BetweenCondition)
, it should be(BetweenOperation)
. Also in some descriptions, the wordcondition
is used again, that would change as well.
Did I get that right or what other changes would you propose?
I think that was probably right.
I donāt really care what stuff is called, I would just like consistency in terminology. Unfortunately SmartThings has always been hopeless in that regard (using āstateā instead of āattributeā being an ongoing issue).
Hi, @daviper.
Not so far, the feature requests can take some time to be processed and developed. I already reached out to the team to get more feedback
Just wanted to very belatedly revisit this and say the developers of the Core SDK would appear to fall into the āif is an actionā camp in this regard. I guess they read the API.
Hi @nayelyz ,
Any news on this ?, almost 9 months later I donĀ“t see anything that can solve this problem with Routines yet and no needing any scripting.
Thanks for any update.
Hi, @Michaelw,
As @niquini shared above, the SmartLighting feature was migrated and you can create routines to mirror behavior but only for switch devices.
Which devices are you trying to mirror?
Hi @nayelyz ,
It seems this plugin is Regional Blocked.
I am in Brazil and donĀ“t see this smart lighting new plugin option when I go to Add Routine, Discover, Lighthing.
Please nayelyz, can you check if it is blocked and instruct us how to have it ?
I may say that I have two HUBs in two different locations. One of them I even have the Smart Lighting Smartapp groovy (old smartapp that was available some time ago), but on the other I donĀ“t and would like to have this new plugin smart lighting.
Also as a answer I intend to use with switches.
