With such a simple on/off switch device, is there a way I can manually force it to use another edge driver? Just trying to future-proof my network before IDE etc goes away soon. Almost everything else is running edge drivers by now, this is a hold-out
Thanks - no, I had previously cleared out the 2 custom device handlers I had experimented with years ago. Are there any good debugging tools out there to investigate a situation like this?
You shouldn’t need to do anything as the Min Smart Plug is a SmartThings administered DTH and so the functionality should be added to an Edge driver unless they have explicitly said otherwise. The job hasn’t been completed yet.
You could ask @Mariano_Colmenarejo if he can add it to his “Z-Wave Switch and Child Mc” driver. He would need the fingerprints (data section) from the IDE.
Would you be as kind as to point me in the right direction? I enrolled in “Z-Wave Switch and Child Mc” but it did not work and the link to fingerprints in GIT didn’t mentioned the above snippet. I feel like I must be in the wrong spot. Thanks in advance.
Edit - I believe the version I have is “2023-02-16T22:08:01.835237734”
You should confirm you don’t have a different fingerprint. They have a couple similar looking devices, since I know one of them has power metering.
If you joined @Mariano_Colmenarejo ’s channel, that is the driver to install. It should automatically choose that driver since it doesn’t match any of the default drivers.
I believe it does. It’s a MP21Z with model: FF0C
I don’t know much about the source code side of these Edge drivers but thought maybe it was missed in a merge between the 7th and the 16th or if I needed to specify something additional.
Edit - I do see a difference but it isn’t part of the fingerprint above. The mfr, prod, and model all match; however, the type is different. The string above has “1000” and I have “1001” and I suspect that the type matters in the match as well?
