Minoston Outlet MP21ZP Won't Force Delete
I’ve never had a force delete to fail.
I installed the above referenced device using the QR code, and while it did show up on the network, it would not operate. And if I try to remove the device the proper way that won’t work, and if I try to force delete in the Smart things app even when it’s not even connected/plugged into power, that won’t work as it says the device is working properly.
I’ve always been able to figure out anything before, but I’ve never had a force delete not work. Any suggestions?
Use the following to delete it: SmartThings Advanced Web App or my.smartthings.com
Thank you kindly for the simple fix, that’s something I should have already tried.
