Does a small E12 candle bulb fit?
Base Type: E12
Wattage: 3W
SMD Type: 2835 SMD
SMD Qty: 10
Lighting Color: Cool white (6000-6500K); Neutral White 4000-4500K; Warm White 2800-3300K
360°optic angle
Input: AC 85- 265V ( Can be used with voltage of 110V and 220V )
Power consumption: < 3W
Bulb Size: 100mm (L) X 36mm (W)
The light fixture is part of the cabinet or the magnetron? How is the bulb controlled, by a switch nearby or a wall switch?
Bulb Homedepot: https://www.homedepot.com/p/Westinghouse-25W-Equivalent-Bright-White-Torpedo-B10-Dimmable-LED-Light-Bulb-3304500/206079259
Grtn Ben
