Ok, so now that’s all fine. But now it says that there is no supported DTH. Even though I’m connected to your branch and updated it now to the latest version in Smartthings IDE. Have you made a new DTH for the roborock.s6?
Hi there! Can a have some help connecting Ir remote (chuangmi.remote.v2). I’m doing it using DB analyser. My device is there but I can’t select it. And what does this marks means in supported device list on GitHub page? X - not tested? O - works? triangle -??
Running on Synology with latest image. Auto search doesn’t work
I’ve deleted all devices from the mi gateway, removed docker and containers and then rebooted PI. Re-installed carefully as per your Github instructions and then re-added devices.
mi-connector logs can see the gateway and ST app can control the sounds and lighting, devices are added and appear in ST app. Only data is added the first time and then doesn’t update.
I have dropped docker mi-connector-arm logs below if they help. Is there any clue that the database mi_connector only contains data for the mi gateway ?
I would really appreciate your help in getting this running as it is a fantastic DTH for ST.
Is there anywhere else that I could look for logs or clues to help you with this issue or do I have an incompatible mi gateway ?
I have some more errors too
lumi.ctrl_neutral1 and lumi.ctrl_neutral2 can not be added to ST
From history:
TypeError: Cannot convert undefined or null to object
at Function.keys ()
at /usr/src/app/routes/devices.js:61:29
at Object.module.exports.getDeviceTotalState (/usr/src/app/miio/miio.js:1443:5)
at /usr/src/app/routes/devices.js:59:10
at Layer.handle [as handle_request] (/usr/src/app/node_modules/express/lib/router/layer.js:95:5)
at next (/usr/src/app/node_modules/express/lib/router/route.js:137:13)
at Route.dispatch (/usr/src/app/node_modules/express/lib/router/route.js:112:3)
at /usr/src/app/node_modules/express/lib/router/index.js:281:22
at param (/usr/src/app/node_modules/express/lib/router/index.js:354:14)
at param (/usr/src/app/node_modules/express/lib/router/index.js:365:14)
at Function.process_params (/usr/src/app/node_modules/express/lib/router/index.js:410:3)
at next (/usr/src/app/node_modules/express/lib/router/index.js:275:10)
at Function.handle (/usr/src/app/node_modules/express/lib/router/index.js:174:3)
at router (/usr/src/app/node_modules/express/lib/router/index.js:47:12)
Also lumi.motion.aq2 does not detect any motion.
mijia.camera.v1 is in " Not Initialized Xiaomi Devices"
Ir remote learned commands looks like this “nMwmkwlk0mkymEsm05mEsmM2mABCzWYgDsAe4C/gL+Au4A/gDsCxIGHgD+AP4A/goeFl4UXg4+Bh4CHgMeCFcwgA” (I don’t know if it looks right) and doesn’t work for my air condition.
And in the end I’m planing to use Google Assistant to control my home. The only error I found so far is that Roborock S50 is shown as light source. Switching it on it starts the cleaning. When it was connected directly through Xiaomi it was working fine, but I’d like to have it with ST.
Ok, I’ve managed to add switches to ST, using “add to ST” tab. But it looks like ST doesn’t update them right. Even though, I can correctly control them through Google Assistant.
Is this a firmware issue where I need to downgrade the gateway or do I have a faulty Xiaomi gateway and purchase another ? I have 17 sensors that I would like to integrate with ST so I am happy to continue to try and work this out.
Apologies but I don’t understand, the gateway is on the lan and itself communicating with ST but not the zig bee connected sensors. Are you talking about the switch that needs activating after tapping help area 10 times On Xiaomi home app ?
Hi Chals!, sorry to bother you, could you try add the speaker functionality, Temperature and Humidity Sensor information on the Hub V2 (Xiaomi Gateway2)?, I’ll like to use it as an alert notifications and temp sensor on WebCore.
Regards!
Many thanks for all your help in tracking this down.
It was me to blame with accepting the Xiaomi Home app the option to update the firmware on my gateway before switching on the developer mode.
I can see that you’ve updated the instructions on GitHub to warn other users of this fact with the V3 gateway, thank you;
If Port is closed xiaomi gateway doesn’t report zigbee status to mi connector anymore.
You have to buy new one and enable a lan protocol first, don’t firmware update first!!!
Or have a look this link
I have now done the psm-set network.open_pf 3 command and it is all working perfectly.
Thank you for your support. Cup of coffee on the way !!
