So I redid everything as you documented in your installation guide (before I missed to create the config path for the docker container).
As you can see from the picture below, after adding the token they show up in the dashboard, but nothing happens on the site of SmartThings (no device, nothing)
Here the entire connector.log
2019-03-07 07:59:57 [Mi-Connector] info: WebSocket init
2019-03-07 07:59:59 [Mi-Connector] info: Initiallize Ping Processor
2019-03-07 07:59:59 [Mi-Connector] info: Mi Connector Version >> 0.0.4.5
2019-03-07 07:59:59 [Mi-Connector] info: {“st”:{“app_url”:“”,“app_id”:“”,“access_token”:“”},“connector”:{“port”:30000,“websocketPort”:30001},“xiaomi”:{“find_limit_time”:“30000”,“motion_reset_time”:“4900”,“find_mode”:“auto”},“devices”:{“list”:},“db”:{“host”:“localhost”,“port”:3306,“password”:“password”}}
2019-03-07 07:59:59 [Mi-Connector] info: Save Config >> {“st”:{“app_url”:“”,“app_id”:“”,“access_token”:“”},“connector”:{“port”:30000,“websocketPort”:30001,“address”:“”},“xiaomi”:{“find_limit_time”:“30000”,“motion_reset_time”:“4900”,“find_mode”:“auto”},“devices”:{“list”:},“db”:{“host”:“localhost”,“port”:3306,“password”:“password”},“graph”:{“height”:40},“log”:{“enable”:true},“ble”:{“enable”:false,“flora”:{“pollingTime”:60},“temperature”:{“pollingTime”:60}},“ir”:{},“ping”:{“list”:},“user”:{“name”:“admin”,“password”:“12345”},“token”:{“value”:“”,“enable”:false}}
2019-03-07 07:59:59 [Mi-Connector] info: DB Config >> {“host”:“localhost”,“port”:3306,“user”:“root”,“password”:“password”,“database”:“mi_connector”}
2019-03-07 07:59:59 [Mi-Connector] info: ----------------------------------
2019-03-07 07:59:59 [Mi-Connector] info: Initialize >> Auto Detect Device!
2019-03-07 07:59:59 [Mi-Connector] info: Save Config >> {“st”:{“app_url”:“”,“app_id”:“”,“access_token”:“”},“connector”:{“port”:30000,“websocketPort”:30001,“address”:“”},“xiaomi”:{“find_limit_time”:“30000”,“motion_reset_time”:“4900”,“find_mode”:“auto”},“devices”:{“list”:},“db”:{“host”:“localhost”,“port”:3306,“password”:“password”},“graph”:{“height”:40},“log”:{“enable”:true},“ble”:{“enable”:false,“flora”:{“pollingTime”:60},“temperature”:{“pollingTime”:60}},“ir”:{},“ping”:{“list”:},“user”:{“name”:“admin”,“password”:“12345”},“token”:{“value”:“41c213232288ef514352ba4783b12ac3afede016b72e824608a5b857fabfd94a56fd961f1222008a096e626c1d46cf6b”,“enable”:false}}
2019-03-07 07:59:59 [Mi-Connector] error: DB is disconnected >> Error: connect ECONNREFUSED 127.0.0.1:3306
2019-03-07 07:59:59 [Mi-Connector] warn: Finded >> But Mi-Connector can’t get token from this device!!! id(78920401)
2019-03-07 07:59:59 [Mi-Connector] warn: Finded >> But Mi-Connector can’t get token from this device!!! id(87093336)
2019-03-07 07:59:59 [Mi-Connector] warn: Finded >> But Mi-Connector can’t get token from this device!!! id(87084244)
2019-03-07 08:00:52 [Mi-Connector] info: Save Config >> {“st”:{“app_url”:“”,“app_id”:“”,“access_token”:“”},“connector”:{“port”:30000,“websocketPort”:30001,“address”:“”},“xiaomi”:{“find_limit_time”:“30000”,“motion_reset_time”:“4900”,“find_mode”:“auto”},“devices”:{“list”:},“db”:{“host”:“192.168.1.30”,“port”:“3306”,“password”:“password1234”},“graph”:{“height”:40},“log”:{“enable”:true},“ble”:{“enable”:false,“flora”:{“pollingTime”:60},“temperature”:{“pollingTime”:60}},“ir”:{},“ping”:{“list”:},“user”:{“name”:“admin”,“password”:“12345”},“token”:{“value”:“41c213232288ef514352ba4783b12ac3afede016b72e824608a5b857fabfd94a56fd961f1222008a096e626c1d46cf6b”,“enable”:false}}
2019-03-07 08:00:52 [Mi-Connector] info: DB Config >> {“host”:“192.168.1.30”,“port”:“3306”,“user”:“root”,“password”:“password1234”,“database”:“mi_connector”}
2019-03-07 08:00:52 [Mi-Connector] error: DB is disconnected
2019-03-07 08:01:01 [Mi-Connector] info: Sensor Live Logging >> Disabled
2019-03-07 08:01:01 [Mi-Connector] info: Save Config >> {“st”:{“app_url”:“”,“app_id”:“”,“access_token”:“”},“connector”:{“port”:30000,“websocketPort”:30001,“address”:“”},“xiaomi”:{“find_limit_time”:“30000”,“motion_reset_time”:“4900”,“find_mode”:“auto”},“devices”:{“list”:},“db”:{“host”:“192.168.1.30”,“port”:“3306”,“password”:“password1234”},“graph”:{“height”:40},“log”:{“enable”:false},“ble”:{“enable”:false,“flora”:{“pollingTime”:60},“temperature”:{“pollingTime”:60}},“ir”:{},“ping”:{“list”:},“user”:{“name”:“admin”,“password”:“12345”},“token”:{“value”:“41c213232288ef514352ba4783b12ac3afede016b72e824608a5b857fabfd94a56fd961f1222008a096e626c1d46cf6b”,“enable”:false}}
2019-03-07 08:01:50 [Mi-Connector] info: Save Config >> {“st”:{“app_url”:“”,“app_id”:“”,“access_token”:“”},“connector”:{“port”:30000,“websocketPort”:30001,“address”:“”},“xiaomi”:{“find_limit_time”:“30000”,“motion_reset_time”:“4900”,“find_mode”:“auto”},“devices”:{“list”:},“db”:{“host”:“192.168.1.30”,“port”:“33006”,“password”:“password1234”},“graph”:{“height”:40},“log”:{“enable”:false},“ble”:{“enable”:false,“flora”:{“pollingTime”:60},“temperature”:{“pollingTime”:60}},“ir”:{},“ping”:{“list”:},“user”:{“name”:“admin”,“password”:“12345”},“token”:{“value”:“41c213232288ef514352ba4783b12ac3afede016b72e824608a5b857fabfd94a56fd961f1222008a096e626c1d46cf6b”,“enable”:false}}
2019-03-07 08:01:50 [Mi-Connector] info: DB Config >> {“host”:“192.168.1.30”,“port”:“33006”,“user”:“root”,“password”:“password1234”,“database”:“mi_connector”}
2019-03-07 08:01:51 [Mi-Connector] info: Try to connect DB…
2019-03-07 08:01:51 [Mi-Connector] info: DB is connected
2019-03-07 08:06:23 [Mi-Connector] warn: Find Device Manually but nothing token!!! >> 78920401
2019-03-07 08:06:23 [Mi-Connector] warn: Find Device Manually but nothing token!!! >> 87093336
2019-03-07 08:06:23 [Mi-Connector] warn: Find Device Manually but nothing token!!! >> 87084244
2019-03-07 08:07:40 [Mi-Connector] info: Save Config >> {“st”:{“app_url”:“”,“app_id”:“”,“access_token”:“”},“connector”:{“port”:30000,“websocketPort”:30001,“address”:“”},“xiaomi”:{“find_limit_time”:“30000”,“motion_reset_time”:“4900”,“find_mode”:“auto”},“devices”:{“list”:[{“ip”:“192.168.1.56”,“token”:“de90dd41097447a4d3eaa2b7ff198211”}]},“db”:{“host”:“192.168.1.30”,“port”:“33006”,“password”:“password1234”},“graph”:{“height”:40},“log”:{“enable”:false},“ble”:{“enable”:false,“flora”:{“pollingTime”:60},“temperature”:{“pollingTime”:60}},“ir”:{},“ping”:{“list”:},“user”:{“name”:“admin”,“password”:“12345”},“token”:{“value”:“41c213232288ef514352ba4783b12ac3afede016b72e824608a5b857fabfd94a56fd961f1222008a096e626c1d46cf6b”,“enable”:false}}
2019-03-07 08:07:40 [Mi-Connector] info: Initialize Wi-Fi Device >> Ip(192.168.1.56), Token(de90dd41097447a4d3eaa2b7ff198211), Type(unknown)
2019-03-07 08:07:40 [Mi-Connector] info: Initialize Wi-Fi Device >> Ip(192.168.1.56), Token(de90dd41097447a4d3eaa2b7ff198211), Type(zhimi.airpurifier.ma2)
2019-03-07 08:07:50 [Mi-Connector] info: Save Config >> {“st”:{“app_url”:“”,“app_id”:“”,“access_token”:“”},“connector”:{“port”:30000,“websocketPort”:30001,“address”:“”},“xiaomi”:{“find_limit_time”:“30000”,“motion_reset_time”:“4900”,“find_mode”:“auto”},“devices”:{“list”:[{“ip”:“192.168.1.56”,“token”:“de90dd41097447a4d3eaa2b7ff198211”},{“ip”:“192.168.1.124”,“token”:“6aa1917e369ce3f35e5a8c56e9ee9237”}]},“db”:{“host”:“192.168.1.30”,“port”:“33006”,“password”:“password1234”},“graph”:{“height”:40},“log”:{“enable”:false},“ble”:{“enable”:false,“flora”:{“pollingTime”:60},“temperature”:{“pollingTime”:60}},“ir”:{},“ping”:{“list”:},“user”:{“name”:“admin”,“password”:“12345”},“token”:{“value”:“41c213232288ef514352ba4783b12ac3afede016b72e824608a5b857fabfd94a56fd961f1222008a096e626c1d46cf6b”,“enable”:false}}
2019-03-07 08:07:50 [Mi-Connector] info: Initialize Wi-Fi Device >> Ip(192.168.1.124), Token(6aa1917e369ce3f35e5a8c56e9ee9237), Type(unknown)
2019-03-07 08:07:50 [Mi-Connector] info: Initialize Wi-Fi Device >> Ip(192.168.1.124), Token(6aa1917e369ce3f35e5a8c56e9ee9237), Type(philips.light.moonlight)
2019-03-07 08:07:59 [Mi-Connector] info: Save Config >> {“st”:{“app_url”:“”,“app_id”:“”,“access_token”:“”},“connector”:{“port”:30000,“websocketPort”:30001,“address”:“”},“xiaomi”:{“find_limit_time”:“30000”,“motion_reset_time”:“4900”,“find_mode”:“auto”},“devices”:{“list”:[{“ip”:“192.168.1.56”,“token”:“de90dd41097447a4d3eaa2b7ff198211”},{“ip”:“192.168.1.124”,“token”:“6aa1917e369ce3f35e5a8c56e9ee9237”},{“ip”:“192.168.1.134”,“token”:“f9a112b5681d5eb8be48987f982bbe09”}]},“db”:{“host”:“192.168.1.30”,“port”:“33006”,“password”:“password1234”},“graph”:{“height”:40},“log”:{“enable”:false},“ble”:{“enable”:false,“flora”:{“pollingTime”:60},“temperature”:{“pollingTime”:60}},“ir”:{},“ping”:{“list”:},“user”:{“name”:“admin”,“password”:“12345”},“token”:{“value”:“41c213232288ef514352ba4783b12ac3afede016b72e824608a5b857fabfd94a56fd961f1222008a096e626c1d46cf6b”,“enable”:false}}
2019-03-07 08:07:59 [Mi-Connector] info: Initialize Wi-Fi Device >> Ip(192.168.1.134), Token(f9a112b5681d5eb8be48987f982bbe09), Type(unknown)
2019-03-07 08:07:59 [Mi-Connector] info: Initialize Wi-Fi Device >> Ip(192.168.1.134), Token(f9a112b5681d5eb8be48987f982bbe09), Type(philips.light.moonlight)
2019-03-07 08:09:57 [Mi-Connector] info: Register Device to ST >> id(78920401) type(zhimi.airpurifier.ma2)
2019-03-07 08:09:57 [Mi-Connector] error: (node:20) UnhandledPromiseRejectionWarning: ReferenceError: err is not defined
at /usr/src/app/routes/registerST.js:52:97
at deviceMap.(anonymous function).target.state.then.state (/usr/src/app/miio/miio.js:1441:9)
at
at process._tickCallback (internal/process/next_tick.js:182:7)
2019-03-07 08:09:57 [Mi-Connector] error: (node:20) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
2019-03-07 08:09:57 [Mi-Connector] error: (node:20) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
