Mi Connector (Xiaomi and Yeelight)
smartapp_misc
dth_sensors
requires_server
smartapp_appliances
(roelofk85@gmail.com) #207
Yes, the fison67 : Xiaomi Remote and the fison67 : Xiaomi Remote TV.
Alsa restarted the mi-connector and the mariadb.
(Chals) #208
How about Xiaomi Remote Custom?
You tried to add xiaomi remote custom.
Let me know the docker & st smartapp log.
(roelofk85@gmail.com) #209
How stupid of me, installed the remote custom and it works like a charm! Thanks you again :smiley:
(Nuno Martins) #210
I’m using mi-connector for some time now, and it’s great. yesterday arrived a Yeelight color V2. But I couldnt add it to mi-connector. I simple cant get the token for the Lamp. Anyone is using this new version of the yeelight?
(Arthur V) #211
Is there any way to run it on windows machine?
(Chals) #212
Only support linux
(Chals) #213
Is this a v2 bulb?
I have a this. It’s added to mi connector.
You can get a token.
(Nuno Martins) #214
Yes. Is that model. Can you point me to the method that you used?
(Chals) #215
I just got token on iPhone with backup db.
Take a look ‘IOS’ part
(fabrizio) #216
Hello I have been using the Connector on a raspberry for several months and it is great and very stable. Last week I added the smoke sensor (it was still connected directly to SmartThings). if I go to the connector I see it but it is not get recognized. Is this sensor among the supported ones?
I got the X close to it. In the IDE I have the xiaomi Smoke Detector v 0.0.1
(Chals) #217
Do you disconnect a smoke sensor from ST and add to Mi Home?
(fabrizio) #218
Yes it was the only remaining zigbee sensor connected to ST as all the other are all zwave. I thought it could make sense to get xiaomi zigbee sensors (I have ten others) connected to the xiaomi gateway and then to ST with the mi connector.
(Chals) #219
Upload your web dashboard and logs here plz.
(fabrizio) #220
I tried to reinstall from scratch and now I don’t see it anymore
(Nuno Martins) #221
thanks. It worked with that way… :slight_smile:
(Chals) #222
It looks like no smoke device belong to Xiaomi Gateway.
You can see a smoke device in Mi Home app?
(fabrizio) #223
It works now. Readded the smoke sensor!
Thanks for the help
(roelofk85@gmail.com) #224
Your programs worked good for my setup fison, thanks for that!
But thanks to the limitations on SmartThings i’ve switched to Home Assistant, al the Xiaomi products worked instantly!
Do you use that also fison?
(Chals) #225
I also use a Home Assistant.
(Paulo Nóbrega) #226
Hi. I think I’ve just found the post I’ve been waiting for months. I have a ST uk v3 hub and several Xiaomi sensors connected to it. But it’s always a pain to connect them and they loose connection many times and I have to re add them and redo all my pistons.
So, if I’ve read it right, I need to buy a Xiaomi gateway (will Xiaomi gateway 2 do or it’s better a Aqara mi gateway?) and a raspberry pi b+? And do I need a zwave pen for the raspberry?
Awesome work
