I have docker set up and working and I can detect my xiaomi yeelight bedside lamp as not initialised:
When I try and add it its shown in red and no token is being pulled back. I have managed to get the token using PacketSender, but I dont see how I can add the lamp to the database even with this:
Anyone any ideas?
fison67
(Chals)
October 10, 2018, 1:44am
188
Maybe you got the wrong token.
Here is how to get token.
Take that 96 digit key and paste into the following:
http://aes.online-domain-tools.com/
Paste in the key as Text / HEX
Function: AES
Mode: ECB
Key: Enter in 32 0’s
Key: 00000000000000000000000000000000
Change output to HEX
Click Decrpyt.
Maybe result is like this.
3
3
6
f
6
1
7
3
5
0
4
2
4
2
4
2
5
5
5
1
4
a
6
f
3
9
6
a
7
1
4
1
Is Xiaomi air purifier 2S (zhimi.airpurifier.mc1) supported?
Thanks, I’ll try this once I get home. Once I have the token, how do I use that to get add the lamp to mi connector?
fison67
(Chals)
October 11, 2018, 12:52am
191
Manage Device -> Device List -> Add Button
fison67
(Chals)
October 11, 2018, 12:54am
192
Not yet.
‘zhimi.airpurifier.mc1’ is exact name?
When I add that model in mi connector, I will let you know.
Quick question, does it need to have xiaomi gateway for the mi connector to work? Or gateway is optional?
Thanks for the good work
fison67
(Chals)
October 12, 2018, 4:21am
194
WiFi devices no needs xiaomi gateway.
Zigbee devices needs gateway.
Can you offer more info about the API application? I’m trying to rewrite a bit the Vacuum DTH in order to make it more compatible with V2 (differences around fanSpeed) and other smartthings smart apps (like webcore)
fison67
(Chals)
October 13, 2018, 3:15pm
196
I don’t know Vacuum V2 has what speed.
It cannot be set variable speed value. It’s just fixed value.
Let me know the log when you set speed on mihome app, ST IDE log show the speed.
ex) balanced(15), power(100)…
fison67
(Chals)
October 13, 2018, 4:25pm
197
Install a fison67/mi-connector:test or fison67/mi-connector-arm:test version.
And Update a smatapp.
I added a zhimi.airpurifier.mc1.
V2 fan speeds are the following:
101 - Quiet
102 - Balanced
103 - Turbo
104 - Full speed
105 - Mop
fison67
(Chals)
October 21, 2018, 4:59am
199
I added a vacuums2 DTH & updated a smartapp.
Remove vacuums thing first.
Restart Docker.
And if it’s not working, let me know docker log when you set fanSpeed.
fison67
(Chals)
October 21, 2018, 12:10pm
200
I uploaded hubitat DTH at github.
You can use the same docker as smartthings.
Roelof
(roelofk85@gmail.com)
October 21, 2018, 7:10pm
201
Hello Again Fison,
I’m using your connector now for a few month’s and i’m very satisfied!
There is only one thing where i’m strugling with.
I can’t get the IR Remote to work properly.
See attachment.
If i click on “Learn” i see the blue light on the IR remote blinking.
If i’m pointing my original IR remote on the Xiaomi Remote there is nothing happening.
Am i doing something wrong?
fison67
(Chals)
October 22, 2018, 12:46am
202
It is a IR type remote controller?
If it’s a bluetooth or rf, it’s not working with mi remote.
you push a learn button, ir code is just showed up.
Here is sample video.
Roelof
October 22, 2018, 6:55am
203
It’s an ir remote controller, used it before succesfull with the mi home app.
Press learn and then on the button drom the desired remote.
Nothing happens…
EDIT: It works, had to open the MI Home app, open the Mi Universal remote and it’s working!!
fison67
(Chals)
October 22, 2018, 7:06am
204
It must be worked without opening mi home app.
Anyway it’s good.
Roelof
October 22, 2018, 7:14am
205
Another problem, when i try to create a custom device i got a “fail”.
Screenshot:
Added the button with succes, but when i click at “Make a custom” this error happens.
fison67
(Chals)
October 22, 2018, 7:18am
206
Do you add a DTH on ST IDE?
