A light and motion detector is installed in the corridor which switches on the two meross MSL100HK bulbs under a specified lux and when motion is detected.
In the afternoon to 80% brightness, late at night to 20%.
The problem I have is that late at night when the automation runs, for a very short time after it happens the bulb seems to go to 80% brightness and then dims back to 20%.
I have tried setting a delay to 2 seconds but this still happens. It seems like it only does this once after the afternoon routine. Could it be because the bulb always returns to the last set value?
Is there some way to prevent this so that late at night it is only 20% brightness and not a moment higher?
Aqara Motion Sensor P1
Aeotec SmartThings HUB
Thanks very much for your ideas and any suggestions.
