Mechanical Ventilation Heat Recovery (MVHR) integration?
(Robin) #1
I am looking to install an MVHR system in a large UK new build property.
Looking like we are going for the Vent Axia Kinetic Plus B unit which has a BMS RJ11 connector on the main control board.
The only info I can get is this:
A full range of two-way digital signals are available through the RJ11 connector on the control board. The BMS system provider will translate this signal to extract the desired data
Any thoughts on how integration can be achieved?
Can anyone reccomend an alternative unit with better integration, or has anyone integrated an MVHR system before?
