I have just purchased my hub, and a 2 gang MCO switch (310 series). I can manually switch my lights on/off, but I simply cant find my switch on ST when I try to add a new thing.
Please help. What am I doing wrong?
Try to do a zwave general exclusion first, but mco doesn’t work well or fully compatible with ST
Hi
Thanks for the suggestion, but I’ve tried this with no joy. When excluding
Is there anything else to do? I was about to locate ST right next to the
switch on my next attempt.
I am pleased to confirm that locating ST right next to the MCO switch worked perfectly.
hi. Does your MCO switch work OK with Smartthings in the end? I was considering buying the 4-load version (https://www.vesternet.com/z-wave-mco-touch-panel-switch-four-load) but I was worried by a comment above that MCO is not compatible. Could you reflect any learning please like would you buy again, any unreliability, custom or default device handler, etc? Thanks, Rob
