Hi all, I’m hoping you can help. I am wiring up some sonof temp sensor/switches to control my boiler in a complicated hot water system. I have the sensors fitted and connected and giving me the tank temperature however max temperature I can set in automations is 50 deg c, which is to low. Does anybody know if this can be increased or overridden?
Thanks for the response. If you mean, how high do I need to measure, then 85 deg C would do it. I’m trying to use the sensors as a hot water tank controller.
