Anyone ever had success with these at all?
I have had them for 1.5 years but only just had them installed for a couple of rooms barely used. Would like to automate based on ST presence, to combine with Nest. There are unofficial APIs around as the Extra Vegetables guys have proved. https://www.extravegetables.com/products/max-eq-3-trv-heating
But my API skills are not so good https://github.com/Bouni/max-cube-protocol
OpenHab has a “binding” too: https://github.com/marcelrv/openhab2/blob/master/addons/binding/org.openhab.binding.max/src/main/java/org/openhab/binding/max/MaxBinding.java
Any tips appreciated
I’ve got these MAX! eq3 radiator TRVs too, with the cube gateway and some wall stats.
A smartthings integration would be great. Honeywell evohome style system for a fraction of the cost; the MAX TRVs are currently £15 each:
Did you get anywhere with this one?
I know there is a bit of work going on on the Domoticz forum trying to integrate these.
I didn’t. I need to convince a friend who doesn’t use ST to help! (Instead he wrote an application for his server to work with the units)
There is a max EQ3 integration for Domoticz of believe. So I wonder if there is a Domoticz to Smartthings bridge that can be used?
Anyone else had any luck with these EQ3 rad TRVs in SmartThings?
Nexarcho
(Nicholas Exarchos)
January 2, 2019, 2:01am
6
Did anyone ever get any joy in linking up their EQ3 TRVs and or hub to their ST?
No, but there is an integration for HomeAssistant.
Dmitri’s ’ MAX! HOME AUTOMATION ’ might be useful as a gateway to the Cube
http://www.dmitry-kazakov.de/ada/max_home_automation.htm
