Hello,
I’m reporting a Matter/Thread issue with a tado X Smart Thermostat in SmartThings.
Device: tado X Smart Thermostat
Hubs: Samsung TV + Samsung soundbar hub group
Approx. failure time: 22:58 local time (Spain, UTC+2)
What I found:
TV alone on Wi-Fi: works
Soundbar added as secondary hub: works
TV as primary hub, switching from Wi-Fi to Ethernet: thermostat disconnects
TV as secondary hub on Ethernet: works
Soundbar as primary + TV as secondary on Ethernet: works
Later, the thermostat stopped updating again at around 22:58 while the soundbar hub was active on 5 GHz.
I already requested Dump Hub Logs for the soundbar hub and I can enable Account Data Access if needed.
Could you please check whether there is any route/controller/network change causing the Matter/Thread device to lose connection?
