Fairly regularly now I get one, two or sometimes up to four matter over thread devices going offline (mostly, but not exclusively, battery powered devices).
I’ve been experimenting with a technique to get them back online without taking the batteries out or having to re-commission them.
Basically look at the routing path for the device and take the last item in the path before the problem one offline for 5 minutes, This seems to cause the offline battery powered device to join via a different routing device.
I’ve tried this approach about 6 times now and it’s worked on each occasion, but your mileage may vary. It also won’t work if there isn’t an alternative routing device in range for the offline device to use.
In this example to get the den presence sensor back online I removed the bulb from rear lamp for a few minutes.
