Matter Camera UI looks very basic in SmartThings App — generated presentation instead of `matter-camera`?
Yes, that’s the one I included in the report. Thanks again. :smiley:
I’ve also uninstalled and reinstalled the SmartThings app! Just to make sure that the plug-in (/data/data/com.samsung.android.oneconnect/vmf/apk/com.samsung.android.plugin.camera_184603003/Camera Plugin.apk), the gstreamer and certificate (/data/user/0/com.samsung.android.oneconnect/files/ssl/certs/ca-certificates.crt) is up-to-date.
Update: Aqara G350 development firmware 4.5.22 fixes Matter streaming
Good news: Aqara has installed a development firmware on my Aqara Camera Hub G350:
4.5.22 / 4005022
With this firmware, Matter camera streaming now works in the SmartThings app. :smiling_face_with_tear:
This is a very important change compared with the previous firmware versions I tested:
4.5.20 / 4005020
4.5.21 / 4005021
With those versions, the SmartThings app/plugin did start the WebRTC flow. The driver logs showed that the app sent a webrtc.sdpOffer command when opening the camera stream. However, the camera did not return a usable webrtc.sdpAnswer, and the SmartThings app was stuck on the endless loading spinner.
With firmware 4.5.22, this has changed.
The webrtc.sdpAnswer is now populated and contains a valid WebRTC answer, including:
  • Opus audio
  • H.264 video
  • ICE candidates
  • DTLS fingerprint
  • audio as sendrecv
  • video as sendonly
In other words: the camera now completes the WebRTC offer/answer negotiation properly.
So the previous streaming problem was very likely not caused by the SmartThings UI (alone?) and not by the Edge Driver failing to receive the WebRTC start event. The WebRTC start event was visible before. The missing piece was that the camera firmware did not complete the Matter/WebRTC answer path correctly.
What appears to be fixed
  • Matter live streaming now starts in the SmartThings app.
  • The camera now returns a valid sdpAnswer.
  • The WebRTC negotiation now completes successfully.
  • The endless spinner is gone for the live stream.
What still appears unchanged
The broader Matter camera implementation still seems mostly the same. I do not yet see evidence that this firmware adds the larger missing G350 features over Matter, such as:
  • PTZ / pan / tilt / zoom
  • presets
  • privacy mode (?)
  • zones / activity areas
  • siren / chime
  • local recording state
  • AI events
  • native dual-lens / 4K / 2.5K camera model
So this firmware update appears to be mainly a Matter/WebRTC streaming fix, not a full Matter feature expansion.
Still, this is a major step forward: the G350 is now finally usable as a Matter camera in SmartThings, at least for live streaming.
They also said that there’s a basic privacy mode, but I have to do some more research to find out how to set it.
I just bought an Aqara G350 but latest firmware is 4.5.21, so SmartThings can add the camera but I get no video.
Sounds like you fixed this by getting beta firmware 4.5.22, how would I get this?
By knowing the right guy at Aqara.
I’m sorry, but I’d wait for the next firmware release.
BTW: why the f didn’t they release at least 4.5.22 by now? 4.5.21 is buggy as hell.
Watch this:
In short: selling it as a “Matter camera” is false advertisement.
Update: New firmware available for the Aqara G350.
First analysis looks good:
Added the switch capability and some plumbing to the Matter Switch driver and now I can toggle it on and off:
That was the initial reason why I wanted a Matter camera: so I can control it locally.
Motion events:
Did your camera update its firmware when in Matter mode and connected to SmartThings? Or did you have to use the Aqara app to update firmware?
Due to the Matter limitations I’ve kept my camera in Aqara mode and updated via the app.
Yes. The camera is always connected to the Aqara cloud. Matter can be seen as an additional connection to other platforms.
Do SmartThings Matter cameras support remote viewing? If so, is this provided solely via STUN or are Samsung Cloud TURN servers supported?
Yes, SmartThings Matter cameras support remote viewing. Matter 1.5 uses WebRTC for live video/audio streaming and explicitly supports remote access via standard STUN and TURN protocols (not STUN only). SmartThings implements this completely, so both are available. The platform can use TURN servers when a direct/STUN connection isn’t possible.
