Hi, @mkrugman
As you have a V2 Hub, I need more information because those Hubs don’t have the issue where Zigbee devices are dropped, so, this could be a special case and needs more investigation.
Also, there are some reports about the Hue driver, and since that driver uses a different protocol, please post in this thread what you’re seeing so everyone looking at it can see you: UK V2 Hub not communicating with Hue devices (June 2023)
Also, please provide support access to your SmartThings account:
- Confirm the email account registered in the forum is the same one you use for SmartThings. If not, please share it with me over DM
- Enable support access to your account:
- Go to the SmartThings Web (my.smartthings.com)
- Log in to your Samsung Account
- Select Menu (⋮) and choose Settings
- Toggle on Account Data Access
- Select the time period and confirm - In this step, please select “Until turned off”, once the team finishes, we’ll let you know so you can disable it again.
