Does anyone have an app or code suggestion that will turn off a switch if another switch is turned on/off a certain amount of times in a certain time window? Looking for a physical way to turn my alarm (sirens) off. I forgot the house was armed and the sirens went off – just at that moment my iPhone battery died. So now I had no way to control smartthings (or the sirens other then to run around the house to the two sirens and take the batteries out.
Looking for a suggestion on how to physically control the alarm (arm and disarm) which basically means physically controlling A) turning sirens off (probably the easier of the two) and B) changing the mode of smartthings into a “security” mode I have settup which arms doors and windows etc.
i did something simular. I used the double tap as a start and here is what I came up with. It works most of the time.
* Mirror Switch
* Author: Jason E
preferences {
section("When this switch is used...") {
input "master", "capability.switch", title: "Where?"
section("Turn on or off all of these switches as well") {
input "switches", "capability.switch", multiple: true, required: false
section("And turn off but not on all of these switches") {
input "offSwitches", "capability.switch", multiple: true, required: false
section("And turn on but not off all of these switches") {
input "onSwitches", "capability.switch", multiple: true, required: false
def installed()
subscribe(master, "switch", switchHandler, [filterEvents: false])
def updated()
unsubscribe()
def switchHandler(evt) {
log.info evt.value
def recentStates = master.statesSince("switch", new Date(now() - 6000))
log.debug "${recentStates?.size()} STATES FOUND, LAST AT ${recentStates ? recentStates[0].dateCreated : ''}"
if (evt.value == "on") {
log.debug "detected on, turn on other light(s)"
onSwitches().on()
} else if (evt.value == "off") {
log.debug "detected off, turn off other light(s)"
offSwitches().off()
private onSwitches() {
switches + onSwitches
private offSwitches() {
switches + offSwitches
private lastTwoStatesWere(value, states) {
// first get a list of the only the on and off events, so that wakeup events don't mess us up
log.debug "UNFILTERED: [${states.collect{it.dateCreated + ':' + it.value}.join(', ')}]"
def onOff = states.findAll { it.isPhysical() || !it.type }
log.debug "FILTERED: [${onOff.collect{it.dateCreated + ':' + it.value}.join(', ')}]"
onOff.size() > 1 && onOff[0].value == value && onOff[1].value == value
