I have a Minka fan that uses a wall switch (light with dimmer and 3 fan speeds). The wall switch sends RF signals to the fan. I also have two lamps in the room. My goal is to turn both lamps on when I turn the fan light on.
I bought a Bond and connected the fan to the Bond app which makes it smart. Each lamp is plugged into a smart outlet. I then used IFTTT to turn on lamps when fan light is turned on. However, IFTTT only knows when I turn the fan on with an app not with the wall switch. I am much more likely to walk into the room and hit the wall switch and than walk into the room, take out my phone and turn on the fan light.
Any thoughts on how to make the lamps turn on when I turn the fan light on from the wall switch? Because the switch is RF, I do not think I can swap it out for a smart switch.
TIA!
