hi i am work on a custom dth it is a switch
is there away on the main tile to change the tile color from white to re if the switch is on
All the built-in switch dths change the color of the main tile when their on so use one of those as an example…
@krlaframboise
i known the on off changes color I went to hole main tile to change
when i say main tile i mean the first screen were you have the device name ad on or off
The only things you can change in the DTH are the icon and the color of the button…
The blue rectangle around “on” and white rectangle around “off” shown in your screenshot are caused by the backgroundColor attribute.
