Lux limit on Mi light sensor
Recently my Mi light sensors has gotten it’s lux range limited to a maximum of 32 000 which ruins some of my routines.
It reads higher values but trigger values in routines can’t be set higher than 32 000.
Any ideas on how to change this?
I use the standard st edge driver for illuminance sensor.
Interesting, I’m using my own driver because I have an older Lumi version of the lux sensor and the range on mine also changed. The range isn’t configurable.
I can see why it would reasonably be 32 000 for devices using the stock drivers as they had a range of 0 - 32 000 added to the profiles the end of 2022.
However if there isn’t a range being imposed by a device profile somewhere it really should be 100 000 as defined by the capability.
