My files were under Home/pi and I deleted them but for some reason it only creates appCert and localCert and the log indicates a failure to find ‘private.pem’. Here is the log I keep getting:
pi@jacobwtyler:~ $ node runNodeServer.js
Listening on port 5000…
No certs will attempt to generate them this version
{ privateKey:
{ n: BigInteger { data: [Array], t: 74, s: 0 },
e: BigInteger { data: [Array], t: 1, s: 0 },
d: BigInteger { data: [Array], t: 74, s: 0 },
p: BigInteger { data: [Array], t: 37, s: 0 },
q: BigInteger { data: [Array], t: 37, s: 0 },
dP: BigInteger { data: [Array], t: 37, s: 0 },
dQ: BigInteger { data: [Array], t: 37, s: 0 },
qInv: BigInteger { data: [Array], t: 37, s: 0 },
decrypt: [Function],
sign: [Function] },
publicKey:
encrypt: [Function],
verify: [Function] } }
in get CSR
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
{“remote_signs_app_certificate_signing_request”:"-----BEGIN CERTIFICATE-----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\r\njW1fM4XQr9guH3Vv7k7g2FTc+yns\r\n-----END CERTIFICATE-----\r\n"}
6919ee288d5e63afa204c6d0a68eb607d1d506e15a02f28a3a2f02aa4431ec2b
{“access_token”:“6919ee288d5e63afa204c6d0a68eb607d1d506e15a02f28a3a2f02aa4431ec2b”,“token_type”:“bearer”,“refresh_token”:“9016aedfd01abd7e954c4d56c66708d5120890357cc72ad4debe84a36fc32363”,“scope”:“public alexa ifttt”,“created_at”:1510627626}
undefined
undefined
192.168.55.28
fs.js:646
return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
Error: ENOENT: no such file or directory, open 'private.pem’
at Object.fs.openSync (fs.js:646:18)
at Object.fs.readFileSync (fs.js:551:33)
at Hub.initalize (/home/pi/node_modules/lutronpro/lutronpro.js:593:15)
at /home/pi/node_modules/lutronpro/lutronpro.js:686:21
at Request._callback (/home/pi/node_modules/lutronpro/lutronpro.js:159:4)
at Request.self.callback (/home/pi/node_modules/request/request.js:186:22)
at emitTwo (events.js:126:13)
at Request.emit (events.js:214:7)
at Request. (/home/pi/node_modules/request/request.js:1163:10)
at emitOne (events.js:116:13)
at Request.emit (events.js:211:7)
at IncomingMessage. (/home/pi/node_modules/request/request.js:1085:12)
at Object.onceWrapper (events.js:313:30)
at emitNone (events.js:111:20)
at IncomingMessage.emit (events.js:208:7)
at endReadableNT (_stream_readable.js:1056:12)
