Has anyone been able to get the Lutron Pico Zigbee remote connected with any of the GE Zigbee in-wall switches. We’re trying to replace a 3-way setup and this would be a fair simpler solution than rewiring to add a neutral to the remote switch.
Pico remotes use Lutron’s proprietary protocol and is not compatible with SmartThings. Some community members are using SmartThings plus Staples Connect to get some use out of Picos, but that’s a long way around and requires significant technical skill.
There are some other options depending on your specific needs. These are discussed in detail in the following topic.
