LUA Usage Question - Accessing an attribute
Still getting my feet wet with the LUA Architecture. Trying to retrieve an attribute and somehow my syntax is not correct.
I can issue a command:
device:emit_component_event(device.profile.components.switch1, capabilities.switch.switch.off())
but I can’t seem to find the right syntax to retrieve the capability.
local state = capabilities.switch1.switch
Not sure what the syntax needs to retrieve a capability attribute.
It should be something like this:
local state = device:get_latest_state("switch1", "switch", "switch")
Here’s the documentation:
https://developer.smartthings.com/docs/edge-device-drivers/device.html#st.Device.get_latest_state
