Hi, could someone send me a 15/50 code please. Thanks.
done___________________
Also, Iâve noticed that the bulbs that @crispyward mentioned for $11.24 seem to be no longer carried by many Loweâs stores. I bought them for $9 a couple months ago, but my local store didnât have enough to cover my order. They never restocked, so finally, I went in last week and they upgraded me to the A19 tunable for the same price.
While I was there, I noticed a new item# for the whites (though they had none in stock) at a higher price than the old ones and there were 2 versions of the tunable whites (though there donât seem to be any differences).
TLDR; get those $11.24 while you can.
I noticed there are 3 different dimmable white A19 listed on website. Specs are the same, so looks like Sylvania is following Philips lead and just releasing new/different bulbs and not changing the name/specs just to confuse the consumer. Lucky break getting upgraded to tunables for same price.
470000 then any 4 numbers xxxx then current code 4 numbers.
Ex 470000xxxx6200
Plug that number into a bulk check digit calculator like
http://www.morovia.com/bulk-check-digit-calculation/index.php
It will output the correct last digit so u donât have to keep trying 0-9 until you get the right one.
Actually itâs 47000RABCDcode(X)
Leave X out of calculator, that is what you are generating
you can run R as 0-9 at one time and get 10 codes with the valid X
If always using 470000, that is why all your codes are coming up as previously used.
I would also vastly appreciate a 15/50 code. I have a 10% off movers code I can give in return!
Could really use a 15/50 code for a purchase! Thanks.
Done & Done
Circling back to confirm I got everything I ordered. Amazing deal. Now Iâve got 5 Protects to install today and that completes my smoke detector replacement project.
Do you generally spring for the faster shipping on these deals? Iâm wondering if I have a better shot if I pay a few extra bucks to rush it.
No, I go for the cheapest. Still gets here fast for me as the fulfillment center is very close. It did take a week to actually ship though.
Fair enough.
One last question, when looking at items that ship from others stores, stock doesnât matter, right? Like if stock is zero but shipping is available, doesnât matter?
Giving my previous order of another item a second shot (not the nest, something else). Letâs see how it goes.
Yes, as mentioned above, orders are not fulfilled from the store(s). They will fill your order from a fulfillment center.
I could use a 15/50 coupon code or 10% off code I would greatly appreciate it .
Could I get a $100 off $50.
Been looking for one of those for a longgggg time.
I do remember there was 20 off 50 for a while
Can someone send me some $15 off $50 please.
I need at least three.
Gottcha covered
