Does anyone have a way to control a TPlink smart Switch via Smartthings using CLI commands.
In my case I want to be able to change Vlan ports from SmartThings for a new HDMI over IP product, that uses Vlans to identify which transmitter should send to which receiver
Ie Transmitter 1 is on Vlan 1 then all receivers on the same Vlan receive that feed
Transmitter 2 is on Vlan 2 then all receivers on the same Vlan receive that feed
So would like to be able to change receivers to different Vlans so video source changes
It would be network port based VLAN
