Hey everyone, I am looking for a keypad that works with Smartthings Monitor and Konnected. I saw the Iris keypad but it requires batteries which I really don’t want to deal with. Is there any other keypad out there that I can use that doesn’t require batteries? I am planning to remove my old keypad so I could use the power wires on the new one if needed.
If you’re comfortable with a bit of soldering / hacking, you should be able to tie your wiring into the Iris keypad (with a voltage converter) and eliminate the battery.
Yeah after searching and talking with other people I found this to be the best solution and going with that. Thanks!
Depending on the exact battery size used, you can probably just use a dummy battery and not need to solder anything at all. (These are also called “battery eliminators.”)
Thanks, I couldn’t remember the right term…
