Logging to ELK server
Hi!
I already created a SmartApp using the code provided by @btk. Thank you, sir. The console log works ok and I can see the json output just fine.
I have an ELK stack running on DigitalOcean. I used their one-click application, so everything is installed ok. I can access Kibana front-end just fine.
Now I need to start sending the data to the server. This is where I get lost. I tried something simple as adding my server IP/port to the config on SmartApp, but then I get:
error org.apache.http.NoHttpResponseException: xxx.xxx.xxx.xxx:5044 failed to respond @ line 164
On DigitalOcean’s tutorial they say:
In order to send logs to your ELK server, you will need to install and configure Filebeat on your other servers.
They explain how to install, and I am supposing that their idea is to send all logs from all other servers to ELK server. So, in my case, my other servers would be my Smartthings actually. But I have no idea how to do this step.
Does anyone know how to finish the configuration?
Edit: I tried to connect via telnet and it worked. Still, ST is not able to connect.
