I have an Aeon Labs DSC06106-ZWUS that I want to use to log when my water heater turns itself on and off (I think it’s operating way too frequently, but want proof). It’s a gas water heater with a power vent, and I’m pretty sure that the vent operates whenever it is heating, so if I plug the water heater into this Z-Wave Metering Switch (leaving it turned ‘on’) the power spike should be sufficient for me to see on a graph over time.
I am using several identical switches for some security cameras, and I see very few entries in the device log in the Android app or the API. In fact, it appears that an entry goes into the log only when I tap either the refresh icon or “reset kwh”, or possibly only when the switch is turned off - not sure if this is accurate or not.
Can someone suggest a good way to get a log of power consumption over time from this device when I leave it turned on all the time?
Thanks.
