Hiya Nezmo,
I never liked the Time column in the CSchwer log. When my log approaches the 2M-cell limit, the Time variable keeps repeating itself. Right now I am almost up to 2M cells, and I see rows where it has said e.g. â07/30/18 03:52:29â for a total of FORTY TWO TIMES, then switched to â07/30/18 10:57:58â and repeated that 12 times. Etc. See the attachment.
I found a workaround and got tired of bugging the wonderful souls that set up the CSchwer log. I stuck in several other timestamps:
LastTime = the latest time out of all the data that contributed to a given CSchwer output row
SendTime = the time as of the point the row is sent from the ST app code, to Google (i.e., the send time as the ST server sees it)
PostTime = the time that the record is posted to oneâs Google Sheet (i.e., the time that Google sees and posts it)
Generally, SendTime and PostTime are only a few seconds apart. But, importantly, PostTime is a completely independent query of the time. This is critically important for when things go wrong. A problem with the original CSchwer code as I see it, is that it assumes everything works simple and right. But things donât always work right. And when they donât, youâre at a loss for knowing the real time(s) involved. It has no safety net.
I have never been able to figure out the code for the CSchwer Time variable myself. I can see how it can get stuck, but Iâm too dumb to fix it. So I simply made these other columns, which I donât mind having anyway.
I have about 2 dozen multisensor devices, and about 100 columns output in each CSchwer log row, every 10 minutes.
The log is a truly wonderful and amazing thing to be getting all this data for free, for two years now.
But still, the Time variable breaks down when oneâs Sheet is getting full. And I donât know how to fix it. So, while I do capture its Time variable, really I mostly ignore it and use my other time variables, basically.
In the appended screen cap, see the âT dittoâ columm. This is a computed column which says +1, +2, etc., for each row where Time repeated itself. You can see where it repeated 41 times. Which is to say, for 42 x 10 minutes (7 hours) it was repeating. All my other time variables updated just fine, though.
As I said before, while I LOVE the CSchwer concept, I never liked how it only had one Time variable - and that one was subject to errors. Nobody seemed to listen. Or, more likely, weâre all exhausted from tweaking, laugh.
I am appending my CSchwer log code (for LastTime and SendTime) and also my Sheets code (for PostTime) if anyone wants to see. You will have to edit your code by hand if you want to add them.
If I were skilled, I might have forked/edited the GitHub code. But I donât feel comfortable doing that. If anyone else wants to include my edits, please do.
My CSchwer code also includes some nice things like the ability to shorten column headers (so they donât take up so much of the screen, as you see in my screen cap), a Zoom To Last Row when opened, and also, my Sheets code repeats certain computed lines each time a row is posted. I have shown the same data on two screens (portrait and landscape) so you can see the difference better.
I use CSchwer to capture âcontinuousâ data like temperature, humidity, light levels, and power, and @KRLaFramboiseâs Simple Event Logger for discrete things (movement, batteries, switches, contacts, presence). Otherwise the discrete columns would have a lot of blanks, which would really cut into the 2M-cell limit of the CSchwer log when multiplied across all my devices. Plus, CSchwer doesnât actually record specific times (it just has a 10-minute window per row, or whatever), but the Simple event Logger captures the exact time.
*** We canât attach .txt files, so here is my current code. First my SmartThings SmartApp code, then search for *** to find my Google Sheets code:
SmartThings SmartApp code that outputs CSchwer log:
- SmartThings example Code for Google sheets logging
- Copyright 2016 Charles Schwer
- Licensed under the Apache License, Version 2.0 (the âLicenseâ); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at:
- http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an âAS ISâ BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
- First used by Mike Fay 6/5/2016 19:14:22
- Abbreviated 3 column-header values 6/6/16, e.g. temperature to temp. Changed back 6/7 sigh.
- 1/1/17: Added code to try to make AMS accelerometers be their own âproperâ box. So I donât have
- to hassle with that odd âSensors Attributes (comma delimited)â thing that doesnât work if you have a comma.
- Look for two with acceleration. Note that âMy Devicesâ suggests AMSs have acceleration AND tamper,
- but the âAeon Multisensor 6 - RV 2.3â code suggests that it is simply using tamper for acceleration.
- I am assuming that that is the case. Also note: Donât use the sensor name straight up as shown in My Devices;
- RVâs code metadata / definition / name / capability section is a little different, and better matches what
- is seen in the code below. So use âaccelerationSensorâ from RVâs code (space removed),
- not simply âaccelerationâ from My Devices.
- 1/30/17: Added PostTime code for a second time variable (in addition to SendTime) to see
- if I can get LaFramboiseâs code working for it,catching it on Sheets side
definition(
name: âGoogle Sheets Loggingâ,
namespace: âcschwerâ,
author: âCharles Schwerâ,
description: âLog to Google Sheetsâ,
category: âMy Appsâ,
iconUrl: âhttps://raw.githubusercontent.com/loverso-smartthings/googleDocsLogging/master/img/logoSheets.pngâ,
iconX2Url: âhttps://raw.githubusercontent.com/loverso-smartthings/googleDocsLogging/master/img/logoSheets@2x.pngâ,
iconX3Url: âhttps://raw.githubusercontent.com/loverso-smartthings/googleDocsLogging/master/img/logoSheets@2x.pngâ)
preferences {
section(âContact Sensors to Logâ) {
input âcontactsâ, âcapability.contactSensorâ, title: âDoors open/closeâ, required: false, multiple: true
input âcontactLogTypeâ, âenumâ, title: âValue to logâ, options: [âopen/closedâ, âtrue/falseâ, â1/0â], defaultValue: âopen/closedâ, required: true, multiple: false
section("Motion Sensors to Log") {
input "motions", "capability.motionSensor", title: "Motion Sensors", required: false, multiple: true
input "motionLogType", "enum", title: "Value to log", options: ["active/inactive", "true/false", "1/0"], defaultValue: "active/inactive", required: true, multiple: false
section("Thermostat Settings") {
input "heatingSetPoints", "capability.thermostat", title: "Heating Setpoints", required: false, multiple: true
input "coolingSetPoints", "capability.thermostat", title: "Cooling Setpoints", required: false, multiple: true
input "thermOperatingStates", "capability.thermostat", title: "Operating States", required: false, multiple: true
section("Locks to Log") {
input "locks", "capability.lock", title: "Locks", multiple: true, required: false
input "lockLogType", "enum", title: "Value to log", options: ["locked/unlocked", "true/false", "1/0"], defaultValue: "locked/unlocked", required: true, multiple: false
section("Log Other Devices") {
input "batteries", "capability.battery", title: "Batteries", multiple: true, required: false
input "temperatures", "capability.temperatureMeasurement", title: "Temperatures", required:false, multiple: true
input "energyMeters", "capability.energyMeter", title: "Energy Meters", required: false, multiple: true
input "powerMeters", "capability.powerMeter", title: "Power Meters", required: false, multiple: true
input "humidities", "capability.relativeHumidityMeasurement", title: "Humidity Sensors", required: false, multiple: true
input "illuminances", "capability.illuminanceMeasurement", title: "Illuminance Sensors", required: false, multiple: true
input "presenceSensors", "capability.presenceSensor", title: "Presence Sensors", required: false, multiple: true
input "switches", "capability.switch", title: "Switches", required: false, multiple: true
input "acceleration", "capability.accelerationSensor", title: "Acceleration", required: false, multiple: true
input "sensors", "capability.sensor", title: "Sensors", required: false, multiple: true
input "sensorAttributes", "text", title: "Sensor Attributes (comma delimited)", required: false
section ("Google Sheets script url key...") {
input "urlKey", "text", title: "URL key"
section ("Technical settings") {
input "queueTime", "enum", title:"Time to queue events before pushing to Google (in minutes)", options: ["0", "1", "2", "3", "4","5","6","7","8","9", "10", "15"], defaultValue:"10"
input "resetVals", "enum", title:"Reset the state values (queue, schedule, etc)", options: ["yes", "no"], defaultValue: "no"
def installed() {
setOriginalState()
initialize()
def updated() {
log.debug âUpdatedâ
unsubscribe()
initialize()
if(settings.resetVals == âyesâ) {
setOriginalState()
settings.resetVals = ânoâ
def initialize() {
log.debug âInitializedâ
subscribe(locks, âlockâ, handleLockEvent)
subscribe(batteries, âbatteryâ, handleNumberEvent)
subscribe(contacts, âcontactâ, handleContactEvent)
subscribe(motions, âmotionâ, handleMotionEvent)
subscribe(heatingSetPoints, âheatingSetpointâ, handleNumberEvent)
subscribe(coolingSetPoints, âcoolingSetpointâ, handleNumberEvent)
subscribe(thermOperatingStates, âthermostatOperatingStateâ, handleStringEvent)
subscribe(temperatures, âtemperatureâ, handleNumberEvent)
subscribe(energyMeters, âenergyâ, handleNumberEvent)
subscribe(powerMeters, âpowerâ, handleNumberEvent)
subscribe(humidities, âhumidityâ, handleNumberEvent)
subscribe(illuminances, âilluminanceâ, handleNumberEvent)
subscribe(presenceSensors, âpresenceâ, handleStringEvent)
subscribe(switches, âswitchâ, handleStringEvent)
subscribe(acceleration, âaccelerationâ, handleStringEvent)
if (sensors != null && sensorAttributes != null) {
sensorAttributes.tokenize(â,â).each {
subscribe(sensors, it, handleStringEvent)
def setOriginalState() {
log.debug âSet original stateâ
unschedule()
atomicState.queue = [:]
atomicState.failureCount=0
atomicState.scheduled=false
atomicState.lastSchedule=0
def handleStringEvent(evt) {
log.debug âhandling string event ${evt}â
if(settings.queueTime.toInteger() > 0) {
queueValue(evt) { it }
} else {
sendValue(evt) { it }
def handleNumberEvent(evt) {
queueValue(evt) { it.toString() }
} else {
sendValue(evt) { it.toString() }
def handleContactEvent(evt) {
// default to open/close, the value of the event
def convertClosure = { it }
if (contactLogType == âtrue/falseâ)
convertClosure = { it == âopenâ ? âtrueâ : âfalseâ }
else if ( contactLogType == â1/0â)
convertClosure = { it == âopenâ ? â1â : â0â }
queueValue(evt, convertClosure)
} else {
sendValue(evt, convertClosure)
def handleMotionEvent(evt) {
// default to active/inactive, the value of the event
if (motionLogType == âtrue/falseâ)
convertClosure = { it == âactiveâ ? âtrueâ : âfalseâ }
else if (motionLogType == â1/0â)
convertClosure = { it == âactiveâ ? â1â : â0â }
} else {
def handleLockEvent(evt) {
// default to locked/unlocked, the value of the event
if (lockLogType == âtrue/falseâ) {
convertClosure = { it == âlockedâ ? âtrueâ : âfalseâ }
}else if (lockLogType == â1/0â) {
convertClosure = { it == âlockedâ ? â1â : â0â }
} else {
def shortEvtName(evt) {
String name = evt.name
if (name == âtemperatureâ)
return âtempâ
if (name == âilluminanceâ)
return âillumâ
if (name == âhumidityâ)
return âhumâ
if (name == âaccelerationâ)
return âaccelâ
if (name == âultravioletIndexâ)
return âUVâ
return name
private sendValue(evt, Closure convert) {
def keyId = URLEncoder.encode(evt.displayName.trim()+ " " +shortEvtName(evt))
def value = URLEncoder.encode(convert(evt.value))
log.debug "Logging to GoogleSheets ${keyId} = ${value}"
def dummyDate1 = new Date(2001, 1, 1);
def eventPostTime = URLEncoder.encode(dummyDate1.format('MM/dd/yyyy HH:mm:ss'))
def url = "https://script.google.com/macros/s/${urlKey}/exec?${keyId}=${value}" + '&SendTime=' + URLEncoder.encode((new Date()).format( 'M/d/yyyy HH:mm:ss', location.timeZone )) + '&PostTime=' + eventPostTime
log.debug "${url}"
def putParams = [
uri: url]
httpGet(putParams) { response ->
log.debug(response.status)
if (response.status != 200 ) {
log.debug "Google logging failed, status = ${response.status}"
private queueValue(evt, Closure convert) {
checkAndProcessQueue()
if( evt?.value ) {
log.debug "Logging to queue ${keyId} = ${value}"
if( atomicState.queue == [:] ) {
def eventTime = URLEncoder.encode(evt.date.format( 'MM/dd/yy HH:mm:ss', location.timeZone ))
addToQueue("Time", eventTime)
else {
def eventLastTime = URLEncoder.encode(evt.date.format( 'MM/dd/yy HH:mm:ss', location.timeZone ))
addToQueue("LastTime", eventLastTime)
addToQueue(keyId, value)
log.debug(atomicState.queue)
scheduleQueue()
- atomicState acts differently from state, so we have to get the map, put the new item and copy the map back to the atomicState
private addToQueue(key, value) {
def queue = atomicState.queue
queue.put(key, value)
atomicState.queue = queue
private checkAndProcessQueue() {
if (atomicState.scheduled && ((now() - atomicState.lastSchedule) > (settings.queueTime.toInteger()*120000))) {
// if event has been queued for twice the amount of time it should be, then we are probably stuck
sendEvent(name: âscheduleFailureâ, value: now())
unschedule()
processQueue()
def scheduleQueue() {
if(atomicState.failureCount >= 3) {
log.debug âToo many failures, clearing queueâ
sendEvent(name: âqueueFailureâ, value: now())
resetState()
if(!atomicState.scheduled) {
runIn(settings.queueTime.toInteger() * 60, processQueue)
atomicState.scheduled=true
atomicState.lastSchedule=now()
// def eventBeginTime = URLEncoder.encode(evt.date.format( 'MM/dd/yy HH:mm:ss', location.timeZone )) // ^ end period timestamp
// addToQueue("BeginTime", eventBeginTime)
private resetState() {
def eventBeginTime = now() // URLEncoder.encode(evt.date.format( 'MM/dd/yy HH:mm:ss', location.timeZone )) // boundary timestamp
def processQueue() {
log.debug "Got into PQ"
// end period timestamp
// def eventEndTime = URLEncoder.encode(evt.date.format( 'MM/dd/yy HH:mm:ss', location.timeZone ))
// addToQueue("EndTime", URLEncoder.encode(evt.date.format( 'MM/dd/yy HH:mm:ss', location.timeZone )))
// addToQueue("EndTime", eventEndTime)
log.debug "Got past EndTime timestamp"
log.debug "Processing Queue"
if (atomicState.queue != [:]) {
def url = "https://script.google.com/macros/s/${urlKey}/exec?"
for ( e in atomicState.queue ) { url+="${e.key}=${e.value}&" }
def eventSendTime = URLEncoder.encode((new Date()).format( 'MM/dd/yyyy HH:mm:ss', location.timeZone ))
url = url[0..-2] + '&SendTime=' + eventSendTime
// def dummyDate2 = Date.parse('MM/dd/yyyy HH:mm:ss', '02/02/2002 02:02:02');
def dummyDate2 = new Date(2002, 2, 2);
def eventPostTime = URLEncoder.encode(dummyDate2.format( 'MM/dd/yyyy HH:mm:ss'))
url = url[0..-2] + '&PostTime=' + eventPostTime
log.debug(url)
try {
def putParams = [
uri: url]
atomicState.failureCount = atomicState.failureCount+1
scheduleQueue()
} else {
log.debug "Google accepted event(s)"
resetState()
// addToQueue("Begin", eventBeginTime)
} catch(e) {
def errorInfo = "Error sending value: ${e}"
log.error errorInfo
*** Google Sheets code (Code.gs) for CSchwer log:
function onOpen() {
// Example taken from https://developers.google.com/apps-script/guides/menus
// 11/16/16 in attempt to get a âZoom to last rowâ function.
// I couldnât get onOpen then Zoom to work without making menu item. - Mike Fay
// 1/30/17 - new code to capture PostTime per Kevinâs 1/22 ST PM.
var ui = SpreadsheetApp.getUi();
// Or DocumentApp or FormApp.
ui.createMenu(âBottomRowâ)
.addItem(âBottomRowâ, âmenuItem1â)
// .addSeparator()
// .addSubMenu(ui.createMenu(âSub-menuâ)
// .addItem(âSecond itemâ, âmenuItem2â))
.addToUi();
menuItem1()
function menuItem1() {
var sheet = SpreadsheetApp.getActiveSheet();
SpreadsheetApp.setActiveRange(sheet.getRange(sheet.getLastRow(), sheet.getActiveCell().getColumnIndex()));
// sheet.getActiveCell().getA1Notation().getColumnIndex()));
return;
// 11/25/16: I tried to make this function to filter on time of day, but
// YOU CANâT USE BUILT-IN SHEET FUNCTIONS IN CUSTOM FUNCTIONS!!! wth?!?
// See https://www.reddit.com/r/GoogleAppsScript/comments/5evpiz/why_wont_this_simple_custom_sheets_function_work/
//function toDnAgain(timestampIn) {
// return 24 * TIMEVALUE(timestampIn);
function doGet(request) {
// From https://github.com/loverso-smartthings/googleDocsLogging/
// which I got to from Log events to Google Sheets [see post 154 for current Github repo and v1.1]
// First created (copied from gitHub) 6/4/16; first working the day after that
// Notes to self: 1) âSheet1â (below) means the worksheet tab, not the spreadsheet
// 2) You must SAVE (Control-S) any changes here before publishing or
// THEY WILL NOT BE REFLECTED IN WHATâS PUBLISHED even though edits persist even across sessions. Wait No -
// 3) In the Publish popup YOU HAVE TO SAY ITâS A NEW VERSION! If you have it on, e.g., â1â, it will keep
// running the particular ALREADY MADE version called â1â. (It is doing version management behind the scenes.)
// Many thanks to John LoVerso for all his help to a GitHub newbie!
// 10/22/16: Edit to fix formatting using Riël Notermans in G+ App forum fix at
// https://plus.google.com/u/0/101895821219259188815/posts/2UpNYwhQ8zM
Logger.log(request);
if(request != null) {
var ss = SpreadsheetApp.openById("1M2AxCDAZU0xWFDFkA0CSI5vjoZt5eC3GJMGMUY4IgaU");
var sheet = ss.getSheetByName("Sheet1");
var firstRowRange = sheet.getRange(1, 1, 1, sheet.getLastColumn());
var sheetHeaders=firstRowRange.getValues();
// columns start at one, but arrays start at 0, so this is the right number for inserting into an array that will be placed into the columns
var newColumnArrayCount=sheet.getLastColumn();
// initialize new row to be inserted before it gets filled with data
var newRow = new Array(sheetHeaders[0].length);
for(var x=0;x<newColumnArrayCount;x++) newRow[x]="";
for (var i in request.parameters) {
var foundRow=false;
for(var x=0;x<sheetHeaders[0].length;x++) {
if(i.toString().toLowerCase()==sheetHeaders[0][x].toString().toLowerCase()) {
// newRow[x]=request.parameter[i]; // changed to next two lines per Riël Notermans in G+ App forum (see lead-in comments)
var currentpar = request.parameter[i];
if (i.toString().toLowerCase() == "posttime") {
// currentpar = null;
// currentpar = Date.now(); DOESN'T WORK - SEE https://plus.google.com/u/0/101895821219259188815/posts/MayxoFFQvi8
newRow[x] = new Date();
} else
isNaN(currentpar) ? newRow[x] = currentpar : newRow[x] = Number(currentpar);
foundRow=true;
break;
if(foundRow==false) {
if(sheet.getLastColumn()==sheet.getMaxColumns()) {
sheet.insertColumnAfter(sheet.getLastColumn());
sheetHeaders[0][newColumnArrayCount]=i;
newRow[newColumnArrayCount]=request.parameter[i];
firstRowRange=sheet.getRangecft6VGY&(1, 1, 1, sheet.getLastColumn()+1);
firstRowRange.setValues(sheetHeaders);
newColumnArrayCount++;
if(newRow[0]=="") {
Logger.log("setting date");
newRow[0]=new Date();
// Appends a new row to the bottom of the
// spreadsheet containing the values in the array
// var lastRowRange = sheet.getRange(sheet.getLastRow(), 1, 1, sheet.getLastColumn()); // New from John
sheet.appendRow(newRow);
sheet.getRange(sheet.getLastRow()-1, 1, 1, sheet.getLastColumn()).copyFormatToRange(sheet, 1, sheet.getLastColumn(), sheet.getLastRow(), sheet.getLastRow()); // New from SEBASTIAN CORONA FERNANDEZ 11/8/16 in Sheet chat (!)
sheet.getRange(sheet.getLastRow()-1, 5, 1, 4).copyTo(sheet.getRange(sheet.getLastRow(), 5)); // New from me 11/11/16, to copy columns C-H (time math and totals)
*** end of code
