Log entries - Help
I’m getting some entries in my hub log and I’d really like to get rid of them to ease other troubleshooting. They look like they are from Hue but I just can’t figure out why they are there. I’ve removed any unused Hue bulbs (I have also removed them from Hue). The only Hue items I have defined in ST are the Hue bridge and active bulbs. If I load Hue Connect there are zero bulbs to add to ST.
As for the log:
Five entries appear every couple of minutes and they look like this:
Contents of each entry look similar to this:
devicetype:04, mac:0017882339AA, networkAddress:C0A80595, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:
Anyone have any ideas on what might be causing this?
My Hue bridge has a confirmed network id of: 0017882339AA
Thanks in advance for any help!
I have just discovered the same and also has no clue what is it.
I’ve done dome additional debug loging of the event. Here is an ouput for my case:
Is this event a state change? false
event from physical actuation? false
The value of this event as a string: urn:schemas-upnp-org:device:Basic:1
The source of this event is: HUB
Trying to get the jsonValue for ssdpTerm threw an exception groovy.json.JsonException: Unable to determine the current character, it is not a string, number, array, or object
The installed SmartApp id associated with this event: null
event id: 813a77e1-727a-11e9-b562-0a94fb0ffe8a
The hub id associated with this event: ced27eee-9b41-4150-a73c-ac5c32e24f28
device name: null
event description text: devicetype:04, mac:702605F87CEF, networkAddress:C0A80199, deviceAddress:63CE, stringCount:04, ssdpPath:/dd.xml, ssdpUSN:uuid:9d906813-5bb4-4d12-be35-a810cca68ada::urn:schemas-upnp-org:device:Basic:1, ssdpTerm:urn:schemas-upnp-org:device:Basic:1, ssdpNTS:
event raw description: devicetype:04, mac:702605F87CEF, networkAddress:C0A80199, deviceAddress:63CE, stringCount:04, ssdpPath:/dd.xml, ssdpUSN:uuid:9d906813-5bb4-4d12-be35-a810cca68ada::urn:schemas-upnp-org:device:Basic:1, ssdpTerm:urn:schemas-upnp-org:device:Basic:1, ssdpNTS:
The device id for this event: null
event display name: Home Hub
device name: null
event created at: Thu May 09 16:50:09 UTC 2019
event data: null
No idea how I should proceed, so far.
