Lock Polling killing battery
Sometime the ST platform tends to poll excessively almost every few minutes and it’s a little random in that there’s no pattern. You may also want to check if the SmartApp is sending commands to the lock excessively (use the IDE Live Logging) which can be a source of drain.
You should also check out RBoy apps and get a subscription if you like it. We have a custom Enhanced Z-Wave lock DTH which provides a setting to cut down on excessive polling from the platform.
