SmartThings Community-
Here’s a SmartApp to send syslog to a local PHP page via HTTP.
You will need a linux box running Apache + PHP on your local net to receive the data.
I was an Iris user until a few weeks back. I had all my Iris events flowing into AlienVault and then into ElasticSearch. I put the PHP page (code embedded in comments below) on my AV server and had rsyslog route as appropriate.
Enjoy!
RusFM
// LocalEventPoster
// Sends events to a local web server for processing.
// SSL is not supported unfortunately.
// An example receiver in PHP (SmartThingsReceiver.php) that dumps the posted data to syslog-
// <?php
// $data = '';
// foreach( $_POST as $key => $value ) {
// $data .= $key . '=' . $value . '| ';
// $data = rtrim( $data, '| ' );
// openlog( "SmartThings", 0, LOG_USER );
// syslog( LOG_INFO, $data );
// closelog();
// If you run this in AlienVault or any other app that redirects HTTP to HTTPS
// then you will need to create an exception to Apache's mod_rewrite rules so
// the request is not redirected to SSL/443. It will look something like-
// RewriteCond %{REQUEST_URI} !.*smartthingsreceiver.* [NC]
// Add something like this to your rsyslog config file so the events go into
// their own log file-
// if $programname == 'SmartThings' then /var/log/smartthings.log
// if $programname == 'SmartThings' then stop
// definition
definition (
namespace: "RusFM",
author: "RusFM",
description: "Post SmartThings Events to a Local HTTP Listener",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png",
iconX3Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png"
// preferences
preferences {
// these two capabilities should cover all the devices
// pity we have to use the ui to select them and cannot programmatically get them
section("Log These Sensors:") {
input "sensors", "capability.sensor", title: "Which sensors?", multiple: true, required: false
section("Log These Actuators:") {
input "actuators", "capability.actuator", title: "Which actuators?", multiple: true, required: false
} // end preferences
// installed
def installed() {
log.info( "${app.getName()}.installed: running" )
initialize()
} // end installed
// updated
def updated() {
log.info( "${app.getName()}.updated: logging available sensors and actuators" )
// sensors and actuators refer to the sections in preferences
sensors.each { device ->
device.capabilities.each { capability ->
capability.getAttributes().each { attribute ->
log.info( "${app.getName()}.updated: sensor, name=${device.getLabel()}, capability=${capability.getName()}, attribute=${attribute.getName()}" )
actuators.each { device ->
log.info( "${app.getName()}.updated: actuator, name=${device.getLabel()}, capability=${capability.getName()}, attribute=${attribute.getName()}" )
unsubscribe()
initialize()
} // end updated
// initialize
def initialize() {
log.info( "${app.getName()}.initialize: subscribing to available sensors and actuators" )
log.info( "${app.getName()}.initialize: subscribing to sensor, name=${device.getLabel()}, capability=${capability.getName()}, attribute=${attribute.getName()}" )
subscribe( device, attribute.getName(), genericHandler )
log.info( "${app.getName()}.initialize: subscribing to actuator, name=${device.getLabel()}, capability=${capability.getName()}, attribute=${attribute.getName()}" )
} // end initialize
// genericHandler
def genericHandler( event ) {
// Local address of your web server, SSL is not supported (talk to Samsung)
// Format is "IP:port"
def server = "192.168.0.100:80"
// The URL on the above server that will accept the POSTed data and do something with it
def path = "/ossim/SmartThingsReceiver.php"
// log.info( "${app.getName()}.genericHandler: ------------------------------" )
// log.info( "${app.getName()}.genericHandler: ${event}" )
def theBody = ""
theBody += "date=${event.date}&"
theBody += "isoDate=${event.isoDate}&"
theBody += "name=${event.name}&"
theBody += "displayName=${event.displayName}&"
theBody += "device=${event.device}&"
theBody += "deviceId=${event.deviceId}&"
theBody += "value=${event.value}&"
theBody += "unit=${event.unit}&"
theBody += "isStateChange=${event.isStateChange()}&"
theBody += "source=${event.source}&"
theBody += "description=${event.description}&"
theBody += "descriptionText=${event.descriptionText}"
log.info( "${app.getName()}.genericHandler: theBody = ${theBody}" )
def length = theBody.getBytes().size().toString()
def hubAction = ( new physicalgraph.device.HubAction( [
method: "POST",
path: "${path}",
headers: [
"Content-Length":"${length}",
HOST: "${server}",
"Content-Type":"application/x-www-form-urlencoded",
"Accept-Encoding":"gzip,deflate"
body:theBody
// log.info( "${app.getName()}.genericHandler: hubAction = ${hubAction}" )
try {
sendHubCommand( hubAction );
} catch( ex ) {
log.error( "${app.getName()}.genericHandler: exception caught, ${ex}", ex )
} // end genericHandler
