Local vs cloud for identical devices
Trying to understand the following: I have two identical zigbee lightbulbs, both used in the same automation (and only this automation). Within the IDE, one shows local execution while the other shows cloud.
What would cause this difference? And can I update the cloud one to execute locally so it’s more reliable?
Same device handler for both?
Yes, exactly the same (at least as far as I can tell.) Hence the mystery.
Display Name Type Location Hub Zigbee Id Device Network Id Status Execution Location Last Activity
basement light 2 ZigBee Dimmer Home Home Hub 7CB03EAA00A52D4D 91F2 ONLINE Local a few seconds ago
Basement light 1 ZigBee Dimmer Home Home Hub 7CB03EAA00A52621 3F10 ONLINE Cloud 3 minutes ago
Brand and model of the bulbs?
Sylvania (Osram)
  • zigbeeNodeType: ROUTER
  • firmwareManufacturerCode: 4364
  • application: 01
  • endpointId: 03
  • firmwareImageType: 93
  • manufacturer: OSRAM
  • model: LIGHTIFY A19 ON/OFF/DIM 10 Year
OK I think I solved this: there was an errant device handler with the same name that had slipped into my device types. This one was causing the cloud execution.
