Any idea why an Ikea motion sensor routine to turn on lights based on motion is run locally, but a routine using the same sensor and lights to turn them off based on no motion is not local?
Both routines are only triggered by the motion sensor and have no other conditions
try editing the one routine that is not local, add a space after the routine name and Save. see if it changes to Local
We would need to see the complete routine, but my guess would be that there is a timer/duration of some kind in the turn off routine. Some of those will not run local even if the device is eligible to run local.
The solution that @jkp is definitely the first thing to try. However vif that doesnât work the what @JDRoberts said will be the next thing to investigate. You will need to provide a full screen shot of the automation to determine if something else is causing the automation from running locally.
Ok, I tried adding the space, made no difference.
Here are the two routines.
The one marked local has the home symbol beside it, the other one does not.
@JDRoberts @jkp
you put it there for 5 minutes. When she has this condition she is not local
Really?
Why on earth does the hub need to reference the cloud to wait for 5 mins
The official explanation is that they havenât finished moving all features from the cloud to local yet, but they arenât promising exactly which features will be in the finished product. But right now, itâs not timers.
It doesnât. It does, however, need the code to handle âremainsâ to have been implemented in the hub firmware. Or alternatively if the routine was written using the older âremainsEqualâ and that is to be superceded (all I know is that âremainsâ has been documented and âremainsEqualâ hasnât) it may need the Routines to be tweaked to generate different code. Or both.
Iâve noticed that often when I edit routines now, they often end up being local when Iâm done. So I went through many of my local devices that are triggered only by time and it appears that simply making and undoing an edit prompts a save, which then appears to make it local execution. Sounds like your approach is doing the same thing. Iâm curious what other actions can be âmovedâ to local?
Iâm seeing the exact same thing.
Oddly enough, in my motion detected rule I have it set to turn off the light(s) after 5 minutes.
That rule is listed as having local execution.
