In the case of the Blink for Home App, this feature appears to only be partially implemented. Using a thirdparty DeepLink tester I was able to surface Scheme = immedia-blink
What’s interesting is that came from a function name “com.airbnb.deeplinkdispatch.DeepLinkActivity”
I found a github library with simliar names and some example DeepLink code:
I have yet to be able to create a URL that can launch the Blink app directly with only having the Scheme implemented and (apparently) no other Intent Filters. I suspect Blink will eventually get this implemented, but wanted to share what I was able to unearth thus far…
Well this is interesting. I inadvertently discovered that while certain links won’t launch the app directly, they will “app switch” to it, if it is already running.
Here’s a working URL to launch the blink app – keep in mind it has already be running: intent://#Intent;scheme=immedia-blink;package=com.immediasemi.android.blink;end
There’s likely a better way, lots of trial and error without knowing what is and isn’t defined in the app.
Minor update, but after my post above I was able to strip down the URL further. This makes no material difference other than a shorter URL and clarifying what is or isn’t required to make the link work.
This still only works when the Blink App is already open, it will not invoke the app itself. For that, Blink needs to add additional “Intent” triggers to their app. (Which, if they do, could allow direct linking to specific pages such as the clips log…)
