Need some help here. I have reviewed the posts regarding the Linear garage door opener not working with Chamberlain Panels that have the Time/Temperature and motion sensor.
Is this an issue with the LED/LCD panel that can be corrected with replacing it with a push button/ motion sensor panel or is it an issue with the motion sensor?
Also I have 4 wires going into the garage door opener itself. I have tried a couple of combinations and have traced the wires back to the wall control as well.
Any help would be appreciated. I’ve attached some pictures of my unit.
What did you do? I have an almost exact setup, but mine is branded LiftMaster with temp and motion sensors (and battery backup), but the model before myQ. I’ve yet to figure out what I want to do to handle the garage door automation and status detection.
It was a stupid simple fix actually. I think so simple that is why I missed it. Actually all I did was replace the Wall mount panel with one that didn’t have the Temp and Time panel and only the Push button and the motion. Worked like a charm after that and the Motion still works.
So I have to lose the existing control panels? Mine are LiftMaster 398LM, functionally the same as yours pictured above. This was one of the reasons I was shying away from the myQ retrofit package, as I didn’t want to replace the panels.
@jlv I replaced my panel from the previous picture to this one. The Linear now works and I still have the motion capablities. For me the time and temperature aspect wasn’t that important so losing it wasn’t a big issue.
