Lights wont turn on but there is power on the switch
We have 30+ lights wired up but are struggling with this one. It has a line in, load, and neural. It powers up and switches the blue LED on and off. Problem is it does not turn on the lights. It is in a bank of 3 switches all are 2 way switches. The 2nd line in comes from the 1st and 3rd from 2nd. Any clue on what could be wrong?
I would check your wiring.
Make sure your neutral connection is tight.
Make sure you get power on load line when on.
Check bulb
Might depend on the switch, but +1 on check your wiring. Switches like the wemo switch have specific “wire to the light” and “wire to power” If you mix them up, it doesn’t work.
