I have 2 lights that keep coming on randomly. What is proper way to troubleshoot to see what turned them on? They don’t both turn on at the same time…
I just recently switched everything from v2 hub to v3.
Brand and model of the lights?
And which version of the SmartThings app are you using?
FAQ: how to tell which version of the SmartThings mobile app that you have
I believe their both ecosmart bulbs. Not sure of the exact model.
I’m using the old version of smarthings
First thing would be to go into the ide and look at the event history for the light. Usually there will be a command event from a SmartApp (they will show the event source as APP_COMMAND).
Are you or have you been using Alexa? She could be controlling your issues.
I’m having this same problem. I already check the Event List of the Device andnotice that it’s turning on itself without any command. Can this be resolved with a SmartApp that check if the device was turned on without a command, if wasn’t turn them off?
I have the same issue. It is the same two lights, and I have lights of the same type that do not randomly turn on…
